33s with 3" suspension? - JeepForum.com
post #1 of 9 Old 02-07-2002, 03:41 PM Thread Starter
JeepN87
I own a stock 87 YJ Wrangler and have been looking to get a lift and some bigger tires. I have heard good things about Rough Country suspension lifts, and I'm looking at getting a 3" lift. I have heard you can easily run 33s with a 3" suspension, but lately i read somewhere that you don't want to go any higher than 31s. Will the 33s fit with the 3"RC lift? thanks for your help
Nick
87 YJ 4.2L
JeepN87 is offline
post #2 of 9 Old 02-07-2002, 03:46 PM
YJ Dude
My opinion is that a 3" lift running 33's is very borderline. You may have some rubbing. You may want to go with a 4" and be done with it. Then again not all lifts are created equal. That rule also goes for tires too.
94 YJ, 2.5, 4" ProComp Lift, 33's,
EZ Locker, Warn M8000 winch, Home made tire/jack carrier, nurf bars.
YJ Dude is offline
post #3 of 9 Old 02-07-2002, 08:14 PM Thread Starter
JeepN87
Thanks for the help YJdude. does anyone else have any opinions on that or is anyone running 33s with a 3" RC lift? And if so any pictures? I'd like a little more input. thanks everyone
Nick
87 YJ 4.2L
JeepN87 is offline
post #4 of 9 Old 02-07-2002, 08:21 PM
osburn
osburn's Avatar
I think 33s are a tough fit under a 4" lift.
Matt Osburn
Score 1032
osburn is offline
post #5 of 9 Old 02-08-2002, 06:25 AM
Atropine
Atropine's Avatar
I am running the RC 3 inch lift with 33's. It rubs under heavy flex (especially with the sway bars disco'd) If you not planning on doing a lot of off-roading until your rig is done, you can do what I did and do the suspension first followed by a Body lift further down the road. pics are up on my website I think its in my signature.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #6 of 9 Old 02-08-2002, 11:38 AM Thread Starter
JeepN87
Thanks Atropine, that helps alot, and the jeep looks good. If i WERE to get a 2 inch body lift along with the 3" RC lift, would that eliminate rubbing, and would I have to trim fenders? thanks again for answering all my questions guys
Nick
87 YJ 4.2L
JeepN87 is offline
post #7 of 9 Old 02-08-2002, 12:34 PM
Atropine
Atropine's Avatar
I am actually going with a 1 inch shackle lift,1 inch body lift and trimming my fenders (I saw how HUBDEEPs turned out and now im convinced). I'll let you know how it turns out. I figure if I need more room still I can put another 1 inch puck on. You should see this by the end of the month.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #8 of 9 Old 02-08-2002, 01:29 PM Thread Starter
JeepN87
Thanks alot for your help Atropine, let me know how your Jeep does.
Nick
87 YJ 4.2L
JeepN87 is offline
post #9 of 9 Old 02-08-2002, 04:17 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I have a 4" suspension lift and fit the 33" tires .. check my new homepage for more information about it
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
2" Suspension + 1" Body VS 3.5" Suspension tx_medic YJ Wrangler Technical Forum 13 06-17-2009 08:43 PM
max __" tires on a 3" body 4" suspension! ACB2010 TJ Wrangler Technical Forum 30 05-18-2009 07:24 PM
4" suspension? or 2.5" suspension and 1.25" body? bradp8 TJ Wrangler Technical Forum 30 08-09-2008 09:03 AM
1" or 2" Spring Spacer with 4" Suspension Lift on 2000 TJ iBkickinit TJ Wrangler Technical Forum 12 03-20-2006 08:25 AM
3" suspension or 2" susp and 1" body panhd TJ Wrangler Technical Forum 4 03-01-2002 10:37 PM
