32RH lock up or non-lock up Torque Convertor - JeepForum.com
post #1 of 10 Old 04-23-2013, 12:25 PM Thread Starter
crotzo80
1983 CJ8
I need some help identifying whether or not I have a lock up or non lock up torque convertor, The Jeep is a 93 YJ with a 4.0 32RH 3 speed auto.
The guy at Transtar was unable to tell me but mentioned that the input shaft of the Trans hsould be osme type of indicator... Any help would be greatly appreciated!
crotzo80 is offline
post #2 of 10 Old 04-23-2013, 07:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
http://www.jeepforum.com/forum/f12/3...ockup-1186971/
My information is in post #2. Hopes it helps you.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 10 Old 04-23-2013, 07:42 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The converter is a three element unit, impeller, stator, turbine.
It also has a converter clutch. It is controlled by an electrical solenoid and a mechanical clutch module on the valve body. The solenoid is operated by the PCM
post #4 of 10 Old 04-23-2013, 07:44 PM Thread Starter
crotzo80
1983 CJ8
Hey Laybackman,
Thanks for the information, I saw your post earlier today when searching for info. With this information, does this mean that all the torque convertors for this trans are the same? There is not specific lockup and non lockup type?
Please confirm.
crotzo80 is offline
post #5 of 10 Old 04-23-2013, 08:07 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
From what I have for information all 30RH and 32RH tranny use the same type of TC.
post #6 of 10 Old 04-23-2013, 09:12 PM
W_A_Watson_II
The number of splines should tell you. 26 splines is for the Lock Up, and 27 splines was non-lockup.
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is online now
post #7 of 10 Old 04-24-2013, 04:32 AM Thread Starter
crotzo80
1983 CJ8
So now I have mixed information, can someone confirm either way? Are all torque converters the same for the 32RH, or do they really have two different spline counts?
crotzo80 is offline
post #8 of 10 Old 04-24-2013, 06:04 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
My info came from a FSM BUT that does not mean they are correct. They often made mistakes in printing those books up.
Check the spline count on your and replace it with the same type!
OEM part number 5211 7877 according to the OEM parts manaul
post #9 of 10 Old 04-24-2013, 06:16 AM
W_A_Watson_II
The shop that rebuilt my '94 automatic ordered the Tc from his supplier, and they gave us the Lock-Up unit, and it would not fit/install. Only after counting splines and doing some on-line research did I discover that it was for a Lock-Up tranny, and as I suspected mine wasn't I found the Non-Lockup was a different spline count, they admitted their mistake and shipped me the correct unit.
26 splines (Lock-Up)
27 splines (Non-Lockup)
Will Watson
post #10 of 10 Old 04-24-2013, 10:33 AM Thread Starter
crotzo80
1983 CJ8
Thanks for all the help guys! With the info that I got in the last post, I was able to confirm that I have a no lockup converter. And of course like most others got the wrong one first!
So just to confirm, 26 spline count is the lock up style
And 27 spline count is the no lock up
crotzo80 is offline
