32 inch tire = what rim size? - JeepForum.com
post #1 of 11 Old 10-15-2011, 11:59 AM Thread Starter
BIGJoe29
I have a 1990 wrangler (it sits stock right now) and im trying to figure out what rim size i need if i get 32x11.5 tires. i also have no clue on wat backspacing is and how much i need. im looking at BFG All Terrains T/A KO(what ever that is) and it will be on a 3in lift if that helps. thnx
BIGJoe29 is offline
post #2 of 11 Old 10-15-2011, 12:22 PM
Xpress
I wouldn't push that much, the rear axle won't last long. 31's is the max, and they fit on the stock 15x8 rims.
All about that unibody life.
Xpress is offline
post #3 of 11 Old 10-15-2011, 01:16 PM
giggityjeeper
^^ opinions vary... not sayinghte 35 is strong by no means but I abuse mine regularly with 33 TSL BIAs swampers, so cantsee 31 giving you much grief....
and ya for onlya 11.5 widetire use a 15x8 with about 3.5" of Backspacing
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 11 Old 10-15-2011, 01:22 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Agreed 15x8 with 3.5 - 3.75" backspacing. You might get away with a 7" rim with 11.50 tires, especially BFG AT's with that sweet rim protector.
Luck Favours The Prepared
Anticanman is offline
post #5 of 11 Old 10-15-2011, 01:25 PM
fratis
fratis's Avatar
street and general trail driving on 32s the rear will be fine. at that size a 15x8 is fine. most dont give options on backspacing and its not a huge conscern. ive put together a similar combination and it was too tall. id stick with a 2"-2.5."
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 11 Old 10-15-2011, 01:28 PM
Jeffro06
Jeffro06's Avatar
I ran 33x12.5s on my stock 3.55 geared D35 for years, without a problem, so I'd have to disagree with this. They were on 15x8 rims with 3.75 backspacing (if I remember right).
Jeffro06 is offline
post #7 of 11 Old 10-15-2011, 01:29 PM
07BlackOps
16x8s are a good choice too. I have them on my JK with 4.10 rears!
07BlackOps is offline
post #8 of 11 Old 10-15-2011, 03:36 PM
giggityjeeper
be hard to do with a 15" tire tho.......
post #9 of 11 Old 10-15-2011, 03:45 PM
Jeffro06
Jeffro06's Avatar
The size of the wheel doesn't have anything to do with the gearing, it's the size of the tire on the wheel.....but I'll assume you're running 32's (no I didn't check your profile).
Jeffro06 is offline
post #10 of 11 Old 10-15-2011, 04:13 PM
TheNewbie
I ran 32X11.50's on the stock rims and then went to a 15X8" rim when I went to a 33X12.50 tire.
The stock rims rubbed a bit at full lock. I agree with a 15X8 with 4" or 3/75" of backspacing if you're already buying new rims though.
Go with 4" of BS if you want to stay with a 11.5" wide tire, but go to a 3.75" BS if you want to maybe run a 12.50 in the future. I run my 33X12.50 on a 4" BS and it still rubs a bit at full lock only.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #11 of 11 Old 10-15-2011, 05:19 PM
jeep108
Good sight to learn about wheel specs
https://www.rsracing.com/tech-wheel.html
And i run 33x12.5's on 15x8 rims. Dont remember what backspacing i have but do remember it is less than 3.75" which keeps it from rubbing but stuck out past the stock flares quiet a bit
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
jeep , tires , wheels , wrangler , YJ
17 inch wheels max tire size? urmegr JK Wrangler Technical Forum 4 07-30-2009 09:01 PM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 09:20 AM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 07:38 PM
max tire size with 2 inch bb wncjeeper TJ Wrangler Technical Forum 17 01-31-2008 07:52 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 01:15 PM
