32/36 Issues - JeepForum.com
post #1 of 5 Old 06-05-2011, 11:46 AM Thread Starter
Delta347
32/36 Issues
I put on a Weber 32/36 bcuz my carter seized up and I followed all the instructions and its all together and on the Jeep but Ive tried 2 pressure regulators and can't get the vehicle to start with either on the line. Ive tried spectre and mr gasket. All it does is crank and push fluid but wont start. As soon as I take the regulator out of the line it starts. The regulators are both pushing fluid through when I crank with the hose taken off.
Also the carb wont idle lower than 1,000RPM even once hot and adjusting the settings isn't doing anything for me this is my only potentially driveable vehicle at the moment as my grand cherokee is down for repairs since its coolant is exploding out everywhere from the block.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #2 of 5 Old 06-05-2011, 12:27 PM
Tompatt
1987 YJ Wrangler
have you done the nutter? also I would just take off the regulator for now.
Thomas
-1987 YJ
Tompatt is offline
post #3 of 5 Old 06-05-2011, 02:31 PM Thread Starter
Delta347
It's nuttered. I took off the regulator and it's still idling at 1000 minimum and now that little box on the firewall under the battery is melting wires when it starts.
My iPhone will poison your Android.
Delta347 is offline
post #4 of 5 Old 06-05-2011, 03:07 PM
Tompatt
1987 YJ Wrangler
take a look through this thread, look at post #6. You need to tune your weber just a bit. read the last diagram in the 6th post. should help with getting familiar with tuning.
http://www.jeepforum.com/forum/f12/c...-36-a-1040957/
Thomas
-1987 YJ
Tompatt is offline
post #5 of 5 Old 06-05-2011, 04:08 PM
fatladyvalkyrie
I have not done the nutter on mine. I just put the Weber on a couple months ago and haven't done much with it besides drive around the yard and to the street corner and back. I have a high idle, about 1300 RPM. I assume I'm sucking air somewhere.
Your post caught my eye as my fusible link just melted. I'm guessing that's what melted on yours. Have you made any progress?
I'm not a vigilante --- I'm an undocumented border patrolman
fatladyvalkyrie is offline
2 winter issues? or mabey just time issues? phil823 TJ Wrangler Technical Forum 3 01-03-2011 07:42 AM
90 2.5L idle issues / desieling issues scottsea YJ Wrangler Technical Forum 2 09-18-2009 07:22 AM
New problem, still dealing with electrical issues. UPDATED, STILL HAVE ISSUES!!!!! rustywrangler YJ Wrangler Technical Forum 34 02-17-2009 04:51 PM
4wd issues wahooz04jeep TJ Wrangler Technical Forum 7 12-31-2006 11:05 AM
CV and SYE issues rrust TJ Wrangler Technical Forum 4 12-22-2004 10:32 PM
