30RH Question - JeepForum.com
post #1 of 5 Old 05-07-2010, 03:51 AM Thread Starter
samsonitesamson
30RH Question
I know I have knocked it in the past, but due to recent events I kind of need to convert my 2.5 5 speed to an auto.... my question will any 30rh bolt up and work with my setup, or does it need to be specifically out of a YJ?
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #2 of 5 Old 05-07-2010, 06:06 PM Thread Starter
samsonitesamson
btt anyone?
post #3 of 5 Old 05-20-2010, 04:33 PM Thread Starter
samsonitesamson
Bump? Someone?
post #4 of 5 Old 05-20-2010, 04:51 PM
jbolty
jbolty's Avatar
Where is it from? An XJ? more details
If it's another 4 cyl it should bolt right up. You will need to swap your flywheel for a flex plate and you may also have to change the input shaft on your transfer case.
jbolty is offline
post #5 of 5 Old 05-20-2010, 08:42 PM Thread Starter
samsonitesamson
Actually a TJ, so I didn't know if the electronics would be a mess or not.
30RH questions and Who makes a good rebuild kit for the 30RH/A904 qk99Cobra TJ Wrangler Technical Forum 16 02-27-2010 05:44 PM
Tranny SWAP. 30RH to AX-5 alexr40 TJ Wrangler Technical Forum 4 09-23-2009 10:22 AM
30RH shifting issues TravisHeim TJ Wrangler Technical Forum 3 01-13-2009 08:36 AM
Need help with a 30RH mesteve YJ Wrangler Technical Forum 0 04-30-2008 07:51 PM
30RH to 32RH swap? deathblade556 TJ Wrangler Technical Forum 2 06-18-2007 02:07 PM
