30 spline chromos? - JeepForum.com
post #1 of 14 Old 12-23-2012, 11:26 AM Thread Starter
Pru-J
30 spline chromos?
I have a 94 yj 4.0 stock motor. I want to change out the 27 spline with some 30 spline chromos off a TJ with a locker. One of my person jeep friends says I'll have too truss and sleeve my axle? Any help guys? TIA
JEEP: its not what you buy, its what you build.
Pru-J is offline
post #2 of 14 Old 12-23-2012, 11:36 AM
jbolty
jbolty's Avatar
Depends on what your plans are. Personally I stayed with 27 because spares are readily available and you seldom see broken front shafts; normal the joints break first.
Not sure what the axle splines have to do with trussing. You can truss if you want, or not.
jbolty is offline
post #3 of 14 Old 12-23-2012, 11:43 AM
RockWoRM
RockWoRM's Avatar
I just hope you're refering to the D30 and not the turdy 5.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #4 of 14 Old 12-23-2012, 11:47 AM Thread Starter
Pru-J
Yes the 30 lol I hate that 35. Going to put a 8.8 back there once I'm stateside
Pru-J is offline
post #5 of 14 Old 12-23-2012, 11:49 AM Thread Starter
Pru-J
Well I'm going to have 38s on her when I get back stateside. Trying to make trailer rig out of her lol
Pru-J is offline
post #6 of 14 Old 12-23-2012, 11:56 AM
RockWoRM
RockWoRM's Avatar
In that case go for it. Keep in mind 'if' you do break anything, it may be more expensive to replace since the 30 spline set up is custom. Also, as far as sleeving the 30. The only one I recall doing it on this board is Joe Dillard. But that was b/c he cracked a tube, which IMHO is rare. Of course, with 38's, a truss would'nt hurt. Good luck.
WRM
RockWoRM is offline
post #7 of 14 Old 12-23-2012, 01:00 PM
jeepster93
jeepster93's Avatar
I run 30 spline axle shafts with an Arb locker and ctm ujoints. Nothing is going to break as long as i do not bind it up.
By tj shafts you mean no disco.?
I have also strengthened the tubes too.
A SUPER 30.
jeepster93 is offline
post #8 of 14 Old 12-24-2012, 10:16 AM
RockWoRM
RockWoRM's Avatar
A SUPER 30.
Tom, did you sleve yours too? or something else?
RockWoRM is offline
post #9 of 14 Old 12-24-2012, 10:30 AM
'92 vegas YJ
WRM
And Joe's old sleeved/trussed D30 is doing well under my rig now.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #10 of 14 Old 12-24-2012, 11:48 AM
jeepster93
jeepster93's Avatar
Sleeving it would be the best thing...
NOT what I did, of course. Would make too much sense for me to do it the right way.
So...
I took some left over steel(3/8 inch thick) and made this little ..."thing" that I welded over the tubes.
Does it help??? I have no clue except to say haven't bent them...yet.
Can see the little pieces I welded on the tubes here:
(That piece from the pumpkin to the disco on this side, shorter on the drivers side, but still a welded piece there.)
Here is another pic of a different project that shows a bit of how I welded and cut it to fit:
post #11 of 14 Old 12-24-2012, 12:27 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Nice it does the heart good to know that my old HPD30 is still doing some good.
Joe Dillard is offline
post #12 of 14 Old 12-24-2012, 01:43 PM
fratis
fratis's Avatar
hmm ive broken shafts but never a ujoint. and i had the "small" ones.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #13 of 14 Old 01-19-2013, 06:12 PM Thread Starter
Pru-J
Yeah... I just broke my u joint the other day haha and unfortunately I'm overseas. I order the 1310 spicer hopefully my size isn't the 1330 because I do have the tom woods driveshaft
Pru-J is offline
post #14 of 14 Old 01-19-2013, 06:20 PM
MLJeeper
MLJeeper's Avatar
Ive twisted the splines on the stock shafts and the long side chromo which is also 27 spline. Also snapped a stub shaft. But So far I have not snapped the larger u joint.My breakage of the 27 spline stuff is very rare actually. Even though i would never drop the cash on a set of 30 spline shafts and locker for the Dana 30 I think that would make the setup pretty darn reliable with my 35s.
Still, 38s are too much for a Dana 30 in any configuration. Just my 2 pennies.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
