30-40 mph vibration - JeepForum.com
post #1 of 2 Old 05-25-2013, 10:39 PM Thread Starter
tiffindale
30-40 mph vibration
I have a 94 with a 4.0 and auto. It has a SOA and an 8.8 rear, a transfer case tailshaft kit and a cv driveshaft. I sold it about 3 years ago and now have it back. The last owner installed RE springs. When I got it back there is a vibration from 30-40 mph. It is always slightly there but really noticeable at 30-40. I thought maybe the cv had too much angle so I lowered the transfer case about an inch, No difference. The rear u joint was bad so I changed it, still no difference. I removed the 2 smallest springs from the springpack and lost about 1" of lift, no difference except the rear u joint had an angle to it. I installed a traction bar and adjusted the angle out of the rear u joint but the vibration is still there. I had actually cut the transfer case mount and moved it over to take care of the 8.8 offset. I had no vibrations at all when I sold it. The cv seems tight with no play in either joint. I greased everything but can not figure this out. If i am coasting the vibration goes away. Any Ideas.
tiffindale is offline
post #2 of 2 Old 05-26-2013, 07:08 AM
USMCBuckWild
Is it a driveline vibration?
Ok, do you feel the vibration in your butt or in your hands?
Butt means driveline: engine mounts, tranny mounts, u-joint, bent shaft, bent rim, lost wheel weight (most common culprits)
Hands means its in the front end: bad u-joint, wheel bearing, ball joints, tie rod end, bent wheel, lost wheel weight(common issues)
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
