with 3" susp lift can i add 2" Bomerang shackles without mods to drvshaft yoke? - JeepForum.com
post #1 of 3 Old 09-30-2004, 04:25 AM Thread Starter
ookxtreme
hello,
i just put a 3" susp lift on the islander and want to know if i can do 2" shackles without having a problem with drive shaft, yoke etc....
the lift came with longer pitman arm... rear sway bar extender(something like that)... drop transfer case...
can i do shackles also without a problem?
thanx in advance
CHEERS TO ALL!!
southeastern michigan
1989 blue islander
3" RC susp. lift / new front bumper / new 258 head / carb coming soon /
ookxtreme is offline
post #2 of 3 Old 09-30-2004, 07:32 AM
desertchp
desertchp's Avatar
I've always generally been told anything over 3 to 3.5 inches you need the SYE and driveshaft. Especially if your going to add a 2" shackle. It would really suck to be out on the trail and the first time you have a lot of flex or suspension travel the drive shaft "slips" out and dups your trnafer case oil everywhere. Ive seen it happen and it isnt pretty.
88 YJ 6 cyl, 5 spd, RE 4.5" heavy-duty, Tom Woods driveshaft and SYE, 35x12.50 Goodyear MTR's on 15x8 black streetlock (simulated beadlock), and Pro-Comp MX-6 adjustable shocks
Converted A/C to engine driven air compressor.
desertchp is offline
post #3 of 3 Old 10-02-2004, 08:47 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I helped a friend do a RE 4.5" ExtremeDuty lift with 1" shackle-lift. We installed the 1" T-case drop and it was mostly fine.
He did bust-up his rear driveshaft, so we installed a SYE (AdvanceAdapters) and a new CV driveshaft. We took out the T-case drop and found that he had some crazy vibrations at highway speeds. We re-installed the T-case drop and it has been alright since.
So - what I am tryin' to say with all this - is that a T-case drop for your 4" worth of lift would be ok for now - but if something breaks - go ahead and do the SYE.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
From 2 " BB to 2" susp. lift Badawee TJ Wrangler Technical Forum 10 06-13-2008 01:08 PM
What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift Dwayne93YJ YJ Wrangler Technical Forum 3 06-02-2008 11:15 PM
2" BL ontop of a 4" susp lift, preperation, ect YCP4x4 TJ Wrangler Technical Forum 10 10-23-2006 06:51 PM
2" BB plus 1"BL or 2.5" Skyjacker susp lift plus 1"BL JAXTOY 2 TJ Wrangler Technical Forum 12 03-23-2005 05:50 AM
Susp Lift Question for 2"-3" w/ 2.5L ssg11bravo30 TJ Wrangler Technical Forum 10 07-04-2002 01:36 AM
