3 link with upside down leafsprings - JeepForum.com
post #1 of 10 Old 07-05-2012, 08:53 PM Thread Starter
Dre40
A friend of mine sent me a pick of a jeep YJ with a three link setup with leaf-springs, but the leaf-spring where cut in half and flipped upside down. has anyone seen this? or seen a write up on it?
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #2 of 10 Old 07-05-2012, 09:00 PM
fratis
fratis's Avatar
it used to be very common. dont see it as much. people tend to just use coilovers now.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #3 of 10 Old 07-05-2012, 09:02 PM
USMCBuckWild
I have never seen it with leaves cut in half but I have seen it with full leaves. The front eye used a factory frame mount and the spring rubbed against a specially designed bump stop. The back end was on a spring mount that allows side to side 'twist' of the spring eye. Kinda hard to explain. The wishbone style 3 link allowed it to flex side to side and the drop was amazing. It allows a TREMENDOUS amount of flex, but is absolutely useless on the street. When you hit the brakes, the nose dies and the back end rises up very high. I saw an old straight axle Toyota with this setup and it was on the verge of ridiculous articulation.
USMCBuckWild is offline
post #4 of 10 Old 07-05-2012, 09:17 PM
78vette
You can buy them out of hot rod parts books. Check out Speedway Motors on line they have them. They have a lot of things that make building easyer.
78vette is offline
post #5 of 10 Old 07-05-2012, 09:40 PM
ltrail
1984 XJ Cherokee
Its quarter elliptical.
Good flex, nasty manners.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #6 of 10 Old 07-06-2012, 12:12 AM
moonpie312
That's old school hotrod stuff right there, what its doing on a lifted jeep I have no idea.
moonpie312 is offline
post #7 of 10 Old 07-06-2012, 12:24 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
There was a thread on this a while back too. I think the OP wanted to give it a shot but I remember several people saying the same thing that you did.
Michaelgoesrawr is offline
post #8 of 10 Old 07-06-2012, 04:26 AM
fratis
fratis's Avatar
like mentioned it used to be very common and works very well. it was even offered in kit form from RE. link geometry will determine manners and performance.
fratis is offline
post #9 of 10 Old 07-06-2012, 10:28 AM
ltrail
1984 XJ Cherokee
If it's a trail rig I'd go for it. If you wanna drive to work on Fridays be careful. Its a half and half. Links give good travel, springs you can undo and adjust stiffness. Haven't run one personally but have research them for budget flexibility. They seem to unload ugly downhill with the special bumpstop method and they are better when linked to the axle like the picture. This is because the bumpstop is only deflecting the spring, there is nothing limiting droop. If you going downhill and brake the rear can kick you in the ***. If you link the leaf to axle like the pic the spring acts on the axle during up and down travel.
ltrail is offline
post #10 of 10 Old 07-06-2012, 11:18 AM Thread Starter
Dre40
Its pretty cool. setup but I think if I was going to go that far I may as well use coil springs, or coil overs...
Dre40 is offline
Stock leafsprings looking normal or worn? econstantin YJ Wrangler Technical Forum 9 05-20-2012 05:38 PM
Installed new r.e 4.5" leafsprings from a cj on my yj, help me identify my new vibs. BigDeaner YJ Wrangler Technical Forum 21 11-26-2011 12:07 AM
Leafsprings youngjeepr YJ Wrangler Technical Forum 4 05-29-2011 01:23 AM
offset leafsprings tomis YJ Wrangler Technical Forum 11 11-03-2009 12:22 PM
composing leafsprings zorlac YJ Wrangler Technical Forum 4 04-02-2008 07:11 PM
