3 Inch Body Lift Removal - JeepForum.com
post #1 of 36 Old 07-09-2013, 09:25 AM Thread Starter
omegacab
Planning on taking off a 3" body lift and replacing it with the Jks 1.25" body lift this weekend. Going to start spraying them with PB blaster today, is there anything I should keep a eye out for when lowering the Jeep almost 2 inches?
1994 Jeep YJ
omegacab is offline
post #2 of 36 Old 07-09-2013, 09:31 AM
jbolty
jbolty's Avatar
radiator fan shroud will need relocating
make sure steering shaft collapses
make sure not to crush wires or hoses
why not cut your 3" pucks in half and get two free BL kits?
jbolty is offline
post #3 of 36 Old 07-09-2013, 09:46 AM
lutzke21
just follow the steps in your instructions... replace with your spacers as you go...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #4 of 36 Old 07-09-2013, 10:48 AM
kloppk
X2.. especially about the steering shaft. They usually rust up and won't move.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #5 of 36 Old 07-09-2013, 11:13 AM
YJScrounge
Watch your brake lines...
YJScrounge is offline
post #6 of 36 Old 07-09-2013, 11:30 AM
mrdeath2000
is the JKS kit all new mounts? or just spacers to add to the existing stock mounts? I think its just additional spacers...(problem if you dont have the oe anymore dropping the 3")
I know the daystar kit is stand alone and replaces the OE mounts.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #7 of 36 Old 07-09-2013, 11:32 AM
mrdeath2000
http://www.quadratec.com/products/16...FaF_QgodG18AZw
look at their pics.
Remove and cut the 3" down by 2" or get the daystar kit, UNLESS you still have all the stock mounts and parts in decent shape.
post #8 of 36 Old 07-09-2013, 12:16 PM
UZI4U
My first body lift was with a set of pucks like that. After wasting that money, I bought a set of Daystars to replace them. I wish I had gotten the Daystars to begin with.
MCLMM
UZI4U is offline
post #9 of 36 Old 07-09-2013, 11:57 PM Thread Starter
omegacab
It's just the spacers which are 1.25", all my factory body mounts are still in great shape.
1994 Jeep YJ
omegacab is offline
post #10 of 36 Old 07-10-2013, 12:01 AM Thread Starter
omegacab
Thanks everyone for all the ideas of what to watch for, and cutting the 3" BL is a good idea. I already have the JKS BL just waiting to install.
1994 Jeep YJ
omegacab is offline
post #11 of 36 Old 07-10-2013, 09:26 AM Thread Starter
omegacab
Anyone know if it is bad to use a breaker bar to get the BL bolts out? I dont have a impact and I was reading alot of people say that is the way to go.
1994 Jeep YJ
omegacab is offline
post #12 of 36 Old 07-10-2013, 10:04 AM
YJScrounge
Yep, oil the snot out of them. There may be bloody knuckles
post #13 of 36 Old 07-10-2013, 10:08 AM
calvynandhobbs
calvynandhobbs's Avatar
I'm going to be doing the same thing in a month or two, when I have the time to actually start working on my Jeep. PO started to put a 3" BL in it, but never finished so it has half of them and a couple bolts he could never get out. Already started hitting it with Kroil once a week until I start the work
94 YJ - work in progress
calvynandhobbs is offline
post #14 of 36 Old 07-10-2013, 10:29 AM
WidowYj91
How are u guys oiling them, I can't get to the threads....
WidowYj91 is offline
post #15 of 36 Old 07-10-2013, 10:36 AM
calvynandhobbs
I've got the long red tube on the end of nozzle and have drilled a couple small holes in the floorboard to put that through. I'm going to be doing some work to the floor anyway so a couple 1/4" holes will be easy to repair once the BL repair is finished.
