-   -   3 Inch Body Lift Removal (http://www.jeepforum.com/forum/f12/3-inch-body-lift-removal-1546893/)
omegacab 07-09-2013 09:25 AM
Planning on taking off a 3" body lift and replacing it with the Jks 1.25" body lift this weekend. Going to start spraying them with PB blaster today, is there anything I should keep a eye out for when lowering the Jeep almost 2 inches?
jbolty 07-09-2013 09:31 AM
radiator fan shroud will need relocating
make sure steering shaft collapses
make sure not to crush wires or hoses
why not cut your 3" pucks in half and get two free BL kits?
lutzke21 07-09-2013 09:46 AM
just follow the steps in your instructions... replace with your spacers as you go...
kloppk 07-09-2013 10:48 AM
X2.. especially about the steering shaft. They usually rust up and won't move.
YJScrounge 07-09-2013 11:13 AM
Watch your brake lines...
mrdeath2000 07-09-2013 11:30 AM
is the JKS kit all new mounts? or just spacers to add to the existing stock mounts? I think its just additional spacers...(problem if you dont have the oe anymore dropping the 3")
I know the daystar kit is stand alone and replaces the OE mounts.
mrdeath2000 07-09-2013 11:32 AM
http://www.quadratec.com/products/16...FaF_QgodG18AZw
look at their pics.
Remove and cut the 3" down by 2" or get the daystar kit, UNLESS you still have all the stock mounts and parts in decent shape.
UZI4U 07-09-2013 12:16 PM
My first body lift was with a set of pucks like that. After wasting that money, I bought a set of Daystars to replace them. I wish I had gotten the Daystars to begin with.
omegacab 07-09-2013 11:57 PM
It's just the spacers which are 1.25", all my factory body mounts are still in great shape.
omegacab 07-10-2013 12:01 AM
Thanks everyone for all the ideas of what to watch for, and cutting the 3" BL is a good idea. I already have the JKS BL just waiting to install.
omegacab 07-10-2013 09:26 AM
Anyone know if it is bad to use a breaker bar to get the BL bolts out? I dont have a impact and I was reading alot of people say that is the way to go.
YJScrounge 07-10-2013 10:04 AM
Yep, oil the snot out of them. There may be bloody knuckles :)
calvynandhobbs 07-10-2013 10:08 AM
I'm going to be doing the same thing in a month or two, when I have the time to actually start working on my Jeep. PO started to put a 3" BL in it, but never finished so it has half of them and a couple bolts he could never get out. Already started hitting it with Kroil once a week until I start the work
WidowYj91 07-10-2013 10:29 AM
How are u guys oiling them, I can't get to the threads....
calvynandhobbs 07-10-2013 10:36 AM
I've got the long red tube on the end of nozzle and have drilled a couple small holes in the floorboard to put that through. I'm going to be doing some work to the floor anyway so a couple 1/4" holes will be easy to repair once the BL repair is finished.
The time now is 06:52 PM.
