3.5 lift = drive line dropped - JeepForum.com
post #1 of 8 Old 10-28-2013, 04:08 PM Thread Starter
gg-boy
I just bought a 88 yj wrangler and put a 3.5 inch lift on it. I have the tc lowering kit already installed, but the stock drive line.
Taking off I was getting a vibration that would smooth out pretty quick, only to start again at a little higher speed. the drive line popped off at the tc side.
I have read that a slip yoke eliminator would not be needed but is not sure what else it could be. Could I just add the rear cv driveshaft? I have no clue!!!
gg-boy is offline
post #2 of 8 Old 10-28-2013, 04:10 PM
squarelite
A sye may not be needed, but your factory driveline is most likely too short
squarelite is offline
post #3 of 8 Old 10-28-2013, 04:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Welcome!
A SYE and dc driveshaft is recommended. You can have a Cherokee front shaft cut and balanced at valley driveline in Stockton for relatively cheap.
Luck Favours The Prepared
Anticanman is offline
post #4 of 8 Old 10-28-2013, 06:44 PM Thread Starter
gg-boy
Do i need the sye to add the cv driveshaft? or can i just get a yoke connect the shaft?
gg-boy is offline
post #5 of 8 Old 10-28-2013, 06:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The combination is the winning ticket.
post #6 of 8 Old 10-29-2013, 12:55 AM
GaryEMS
Anti theres also a place in Modesto who did the CV joint on my K5. C and H balancing. He used to build drive lines for Bill Elliot.. great guy.. His name is Chuck.. Just tell him Gary from TBA referred you.. or anyone for that matter whos close to MOtown
GaryEMS is offline
post #7 of 8 Old 10-29-2013, 12:58 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Thanks. I actually go talk to the owner of valley balancing at his Ceres shop when I need work done. Never hurts to network a bit. I will check them out.
post #8 of 8 Old 10-29-2013, 01:01 AM
Imped
Imped's Avatar
You can figure this out using common sense.
Take a look at your rear output and how your drive shaft 'attaches.' It should be quite obvious as to why it's called a slip yoke.
Now pull up handy dandy Google and look at a double cardan drive shaft or a SYE kit, either one or both. It should be quite obvious as to why the rear output yoke is called a fixed yoke.
You will be left with no question at all if you can use a double cardan drive shaft with a slip yoke.
It's as simple as that.
OlllllllO
IndyORV
Imped is offline
