3.5 BDS + 5/8" shackle = too much? - JeepForum.com
post #1 of 4 Old 07-20-2004, 09:53 PM Thread Starter
YJfrom94
I bought my 94 YJ just a few weeks ago, and the other day I had it out wheeling for the first time. It wasn't anything special, just a little mudding on a friends farm. The last owner installed a 3.5" BDS lift on it. When wheeling for the first time, I noticed a loud clunking in the back. I checked what it was and sure enough, the military wrap on the springs was hitting the frame. Now, I'm thinking about getting the 5/8" M.O.R.E. boomerang shackles all around.
My question is, can I still run without an SYE and CV driveshaft if I have that much lift? I haven't noticed any vibrations, unless they are there and I just don't know what to look for. Money is kind of tight right now and I definitly do not have recources to do a SYE. Any suggestions?
Also, the transfer case popped out of 4 HI once on the trail. I put it back and it seemed to stay fine. I'm not sure why, any ideas?
94 YJ 4.0 HO/AX-15
3.5" BDS lift, 33" BFG Mud terrains
So much more to do, so little money.
YJfrom94 is offline
post #2 of 4 Old 07-21-2004, 08:02 AM
Protoxis
that is the Same setup I am running With the Boomerangs all the way around. I do not run a SYE kit and just use the 1 inch t-case drop the only Vibes I get are at about 70mph down the highway and even then they are not that bad (if i did not know any better i would say they are my M/Ts). The jeep is also my daily driver and has been that way for about 1yr. I wheel it regularly HOWEVER I will be getting a SYE this Year with my X-mass Bonus. I would recommend that a SYE should be your next mod when you get the cash
Protoxis is offline
post #3 of 4 Old 07-21-2004, 08:37 AM
johnny1720
johnny1720's Avatar
I also have 1 inch lift shackles and I get sever rubbing on my rear wheel wells when I go offroad.
Do either of you have this problem. I am going to be getting TJ flares soon enough but I am still curious, I have already replaced the rear springs with 5 leaf packs as opposed to the 4 leafs they sent me.
johnny
04 TJ
Warn 9.5ti, Tomken Winch Plate
Rusty's 2 Inch Coil Lift, JKS 1 1/4" BL and MML
LOD Swing Away Tire Carrier
B&M Short Throw, Rear Alloy USA Axle Shafts
33x10.5x15 BFG AT's
johnny1720 is offline
post #4 of 4 Old 07-21-2004, 08:44 AM
Protoxis
johnny
I did but i cut the Rear at a Angle and it took care of that problem i dont like BL's When i got the Jeep it had a 1 inch Shackle lift on it and it the would hit to many things so i put the Boomrange's on
it fixed that it also flexs better and rides better IMO
Protoxis is offline
2" Shackle reversal *** 1" body lift problem mexdealer YJ Wrangler Technical Forum 1 10-06-2009 05:43 AM
Will 2"shackle + 2"body clear 33's? kodyharrell YJ Wrangler Technical Forum 14 07-30-2009 09:46 AM
2.75" or 3", which shackle hanger do I order? fishmanwill YJ Wrangler Technical Forum 0 07-28-2009 11:56 AM
91 yj on 32" tires and 2" shackle lift and tj flares luis92yj YJ Wrangler Technical Forum 4 01-21-2009 07:36 AM
SOA + 4" Springs + 2" Shackle = 33" Tires What do you think lawson1273 YJ Wrangler Technical Forum 55 01-01-2009 07:41 PM
