3/4 ton axle swap has begun!!!! - Page 2 - JeepForum.com
post #16 of 98 Old 10-08-2010, 12:55 PM Thread Starter
highrolrcustoms
i wanted to test fit my springs to determine my front spring hanger location....i am using yj 2.5" lift springs and when i bolted on the rear shackle and put the spring in place i measured and i am showing it moved the hanger back almost 10"s????? it is suspose to be a 6" stretch but i am ok with the extra if that is how it will mount.....i put the rear shackle straight up and down simulating full suspension drop. so when i put the weight on the springs it will put the shackle at an angle. is that correct??? i just want to make sure i get the front hanger position correct. if it is correct i will gain right at 10"s of stretch....why is it that when xj springs are used you only gain 6"s
am i correct so far?? any help would be appreicated!!!!!
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #17 of 98 Old 10-10-2010, 02:29 AM
JeepO7
Before you burn in the welds on the front hangers put the weight back down on the springs to make sure the shackle angle looks good.
JeepO7 is offline
post #18 of 98 Old 10-10-2010, 08:59 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The unloaded spring will sit in a different location than if the weight was of the jeep was sitting on them.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #19 of 98 Old 10-10-2010, 06:44 PM Thread Starter
highrolrcustoms
^^true but the front mount doesnt move so i am guessing that the difference in stretch is the offset pin that the xj spring pack uses and the extra stretch i am gaining is from me using the yj springs...i am running the blue torch stretch kit which is designed to use xj spring to give you a stretch of 6"s....so i am figuring.... subtract the 28 5/8"s from the 23"s on the xj leaf spring measurements and thats where i picked up the extra stretch with the yj springs
xj spring pack measures approx 23" to center pin and 28 5/8" to center pin
where as the yj measures 22 11/16" to center pin on both sides
got my beadlock rings today and thought i would go ahead and weld one up....gona scuff the chrome and paint the wheels black and outter rings red
post #20 of 98 Old 10-13-2010, 12:49 PM Thread Starter
highrolrcustoms
made a little more progress....ground down the calipers to fit the 15" wheels
Blue Torch Side frame plates came in mail so went ahead and welded them on.
also went ahead and finished welding the rings on the wheels for the beadlocks and scuffed them and primed and painted wheels
starting to assemble one of the tire/wheels...had to stop and go get bb's to balance and valve stems
post #21 of 98 Old 10-18-2010, 06:20 PM Thread Starter
highrolrcustoms
got my beadlocks finsihed....with my wifes help
started working on my front axle and got my spring mounts welded on...they are Ruff Stuff +2's
and finally was able to bolt on the front wheels and tires and get it off the jack stands...now i can actually start to see it comming together!!!!!!!!!!!!
here it is before the axle swap
post #22 of 98 Old 10-20-2010, 09:45 PM Thread Starter
highrolrcustoms
made a little more progess...was able to get it sittiing on the ground !!!! going to comp cut the rear this weekend...my btf corners will be here tomorrow!!! Wheelbase is now sitting at 106"!!!!!!
post #23 of 98 Old 10-21-2010, 02:34 AM
chucker440
sweet keep it up
chucker440 is offline
post #24 of 98 Old 10-24-2010, 01:56 PM Thread Starter
highrolrcustoms
finally got it out of the garage!!! got my comp cut guards installed
post #25 of 98 Old 11-20-2010, 09:00 PM Thread Starter
highrolrcustoms
finally got some more parts in the mail.....
rear disc break conversion, rear shock towers for outboarding rear shocks, and flush mount taillights!!! time to start workin on it again
post #26 of 98 Old 11-21-2010, 06:11 PM Thread Starter
highrolrcustoms
got my taillights installed today and started on my disc brake conversion!!!
also changed axle seals...i think they were leaking a little...
post #27 of 98 Old 11-21-2010, 06:12 PM Thread Starter
highrolrcustoms
finished!!! a whole lot cleaner and better working than those old drums!!
post #28 of 98 Old 11-21-2010, 06:25 PM
jeep0312
Looking good. Wanna do an axle swap in mine? Ill take some D60's with 42'' tires. LOL
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #29 of 98 Old 11-21-2010, 07:01 PM
Tompatt
1987 YJ Wrangler
Looking real nice. i wanna see it all come together.
Thomas
-1987 YJ
Tompatt is offline
post #30 of 98 Old 11-21-2010, 07:04 PM Thread Starter
highrolrcustoms
hopefully it will be driveable in next few weeks...just ordered my 538 gears and full spool for the front and the long spline pinion yoke for the sterling 10.25
jeep0312....just bring it up here and we will put some rockwells under it...lol thats what i wanna do next!!
5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 98 11-05-2012 08:26 AM
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 09:46 PM
4.3 install has begun 2cjs YJ Wrangler Technical Forum 10 05-25-2007 10:01 AM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 12:33 PM
Modding has begun 06WranglerX TJ Wrangler Technical Forum 4 05-10-2006 07:10 PM
