3 for 3 - JeepForum.com
post #1 of 16 Old 03-11-2010, 06:26 PM Thread Starter
Five0
3 for 3
Well so far I have posted twice with issues and thanks to all the help from everyone I have found solutions to both problems, so lets try to go 3 for 3. LOL
My 4.0 in the 92 YJ with a 110 thousand on the odometer is very sluggish and about 60mph or so is as fast as it will reach in 4th. When we drop into 5th it's a steady decline until about 50mph and it just stays there unless I hit a hill, (ever see the commercial where the old dude on the bicycle passes his car, yea that's me). I can get back to 4th and it will pick up a little. It will not turn more than 3 grand in 4th or 5th, it just runs out of umph. Here's a list of new parts.
Plugs, wires, cap, rotor, new exhaust, header, new cat, air filter and so on. I will be putting a new in line gas filter on tomorrow but the one on now is not that old according to the previous owner. When I put the header on I saw that the injectors were a little dirty so I ran a can of sea foam but no help so far. I'm running 33's with stock gears and a 4 inch lift. There's no heavy equiment on this thing so it's not that heavy. I don't need to go fast but it should pull a little better.
Any ideas,
Thanks again to everyone for the help, Great Forum.
Five0 is offline
post #2 of 16 Old 03-11-2010, 06:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds only slightly worse than both of our ('91 & '93) 4.0L YJ's with 33's & 3.07 gears.
Regearing should be your priority, IMO.
It is for ours.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 16 Old 03-11-2010, 07:16 PM
Mark05059
easiest way to regear is to find a set of 4cyl axles. (4.10 ratio) and swap them in where the originals are
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 16 Old 03-11-2010, 08:17 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
^^^Yep, spoken for truth!^^^
Max
Mean Max is offline
post #5 of 16 Old 03-11-2010, 08:37 PM Thread Starter
Five0
Well I guess that settles that. I just thought that the little 6cyl should do a little more. Oh well, I guess it's time to start looking for gears. Is 4.10 a reasonable ratio for limited street use?
Five0 is offline
post #6 of 16 Old 03-11-2010, 08:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Mathematically calculated, 3.49 gears would make 33's omn 3.07's "feel" like the stock 29" tires felt on 3.07's gears.
So 4.10 gears on 33" tires would actually have lower gearing than stock.
Play around with the numbers here 4LO.COM :: On-Line Gear/Tire Size Calculators
Max
Mean Max is offline
post #7 of 16 Old 03-11-2010, 08:43 PM
Fhajad
3k in 4th gear?
I pull *** on the highway in 4th. 5th for flat or downhill. I can hit 75 if I'm not facing headwind easily.
Then again, I BARELY press on the gas pedal.
Fhajad is offline
post #8 of 16 Old 03-11-2010, 09:03 PM Thread Starter
Five0
In 5th I can mat it and will not pull past 25 to 28 grand and 50mph or so and it's on it's face. I did forget to mention that I will soon be putting on a set of 35's.
Just because of the way the motor feels, I'm still not sure that all the mechanical stuff is on the up and up so I'm gonna continue to look and go from there. Max, thanks for the chart it will help with geaer selection.
Five0 is offline
post #9 of 16 Old 03-11-2010, 11:29 PM
MJMPC
If you go 35s you WILL have to regear and also change the rearend from a D35 to a Ford 8.8 or stronger.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 16 Old 03-11-2010, 11:30 PM
Fhajad
Yeah, re-gear is a good idea especially if you're going up to 35's.
I also don't even bother with 5th until it's flat or negative tilt, or less then 60mph or so.
Fhajad is offline
post #11 of 16 Old 03-11-2010, 11:35 PM
Yury
1000 appologies to the OP for thread theft but does this work for TJ,s as well?
thank you in advance
Yury is offline
post #12 of 16 Old 03-12-2010, 06:09 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Max, thanks for the chart it will help with gear selection.
I haven't used 5th gear in years.........
Yes.
Max
Mean Max is offline
post #13 of 16 Old 03-12-2010, 07:41 AM
Yury
Originally Posted by Mean Max View Post
Max
thanks MAX
Yury is offline
post #14 of 16 Old 03-12-2010, 08:16 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Any ideas,
that's normal. I had 33's with 3.07 at the beginning of the month. My jeep drove exactly like yours, 5th was just like a slow brake.
I went to 4.10 gears in the last few weeks. Only put 10 miles on in since the switch. Drove it to work today and was SOOOOOO happy with my new shift points I intended to post about it. Its a major improvement. I used a 4cyl front and 8.8 rear. I would do it again in a second.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #15 of 16 Old 03-12-2010, 08:17 AM
SloppyJoseph
Honestly if you are going with 35's soon, you might consider upgrading axles unless you really like swapping them out. I mean since you are already going to do it, you might as well do it right.
SloppyJoseph is offline
