Quantcast 3.0L Mercedes TURBO DIESEL into 1994 YJ - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 3.0L Mercedes TURBO DIESEL into 1994 YJ
Old 08-24-2009, 12:19 PM   #76
nelson1248
Originally Posted by hulkgreen View Post
UNLESS YOU JUST HAVE MONEY TO BURN ON FUEL ...... YOU WOULD BE BETTER OFF WITH A DIESEL !!!
IF I DRIVE IT " NORMALLY " I SHOULD GET 32 MPG AND IF I DRIVE IT LIKE I STOLE IT I SHOULD GET 23 MPG !!!
I HAVE HEARD OF SOME OF tHE CUMMINS GUYS IN 2 WHEEL DRIVE PICK UPS GETTING IN THE 40 MPG RANGE !!!
man i have never heard of anyone getting that good of gas mileage on a diesel engine!
my dad has an F350 and only gets 11 MPG
where in the world can i find a diesel engine to fit into my rig? if its that good ill definitely do the swap!
MOPAR or NO CAR
nelson1248 is offline   Reply With Quote
Old 08-24-2009, 03:37 PM   #77
rficken42
i am very impressed. cant wait to see how it turns out. i may follow in your thread and do a diesel swap of mine own.
1991 wrangler - I6 5spd 4.10s 33x10.5
1998 cherokee - I6 5spd stocker
rficken42 is offline   Reply With Quote
Old 08-24-2009, 06:57 PM   #78
hulkgreen
Originally Posted by 12b4420 View Post
This is a compacted list of everything that I’ve learned on 87 jeep wrangler (617 coversion) - Diesel Bombers
It was the fuel economy that sparked the interest in the Mercedes 5cyl diesel into a Jeep Wrangler swap. I have seen a lot of interest in this project and it can be done.
Wrangler with 3.0 td turbo charged Mercedes diesel engine mated to ax-15 Jeep transmission. The engine is completely mechanical and has no computer making it easier to perform the swap. Your able to transfer all sensors from the Jeep to the Mercedes engine so even the engine gages work as they should. The fuel pump is mechanical and not electric; using the same Jeep fuel tank only making the opening for fuel nozzle bigger. (You may have to go with older fuel tank if it will fit from jeep 87-91.)
The engine mounts must be modified using the original Mercedes motor mounts and bushings. All that is needed is cut off old brackets from jeep. Make new brackets, reinforce them and welded them to the frame.
You reuse the stock jeep radiator. It looks like the jeep has enough room to fit an intercooler in front of radiator. Maybe look at the Volvo turbo intercooler. The power steering hoses were soldered to Mercedes fittings and your able to use original steering gear box.
The vacuum pump needs to connect to your brake booster. Take the original MB line that goes all the way to booster and remove the plastic line and use a rubber hose with a vacuum t connector and put a one way vacuum check valve and connect it all to the booster. The t fitting you will need to connect the rest of your vacuum system on your engine as well as some of the jeep stuff that runs off of vacuum.( fuel pump shut off,some front diff’s)
You will use the stock 4.0L flywheel and starter. Take the stock jeep flywheel and make it fit the Mercedes engine. MB have 12 holes and jeep has 6. Weld the holes and redrill them to fit Mercedes crank.
(measure twice drill once) Use the bolt hole spacer plate that MB has to mock up bolt holes. (When replacing the flywheel, the balance of the engine should be maintained as much as possible.)
Use the stock needle pilot bearing from jeep and also use a ford pilot bearing #14656 (Advance auto parts Ford 1968-86 302,351,400 cu.in.) It fits perfectly into Mercedes crank (outside diameter) then you drill the inside to fit the jeep needle bearing (measure twice cut once)
And as for the adapter you have to be patient and do lot of measuring. You make the adapter use nothing special; just stuff in your garage torches, drill, grinder, welder etc...Use 5/16 steel plate for the
adapter which makes the transmission input shaft fit perfectly into the pilot hole. After finding the center shaft hole use a hole transfer tool and transfer 3 bell housing holes and drill them into 5/16 steel plate. Then put the bell on it and drill the rest of the holes that are used.( Don’t drill bolt holes for starter just yet to be assured your 100% aligned.) Then move over to center of MB block and transfer the dowel pin holes to the 5/16 plate (measure twice drill once) insert the dowel pins and use original MB adapter and drilled rest of the holes. You will need to have 6 holes drilled for engine side (4 bolt holes and 2 dowel pins if I remember correctly)
You want to change the starter over to the Driver side to keep it away from the turbo heat you can use a 97 Dodge Dakota either 3.9 V6 or 5.2 V8 BELLHOUSING .... BOTH Bells will mount the starter to driver side and keep it away from the turbo'd exhaust manifold and they have all necessary provisions to mount the clutch ( just like stock JEEP ) You will need the bell and ALL associated clutch parts if you donor is post 1994. It is a direct BOLT-ON to either a nv3550 or ax 15 transmissions and the WHOLE REASON this is suggested is to move the starter over to the driver-side to keep it out from under the turbo and exhausts HEAT !! Extend the starters wire’s by 12 to 18 inches ( under the oil pan ) and you are good to go !! You use the stock 4.0L flywheel and starter it just moves it to the driver’s side away from the turbo heat ($75 dollar salvage yard bell housing)
It has been done without the Dakota flywheel but you must move the starter from original position upwards toward exhaust manifold to clear bulky Mercedes oil pan, and must make new cutout in bell housing to fit starter. (you can see pic of this on)
Read more: 87 jeep wrangler (617 coversion) - Diesel Bombers (Look at the last pic on the first thread and you will see that the starter was moved)
The engine is a OM617 turbo diesel 630lbs wet should be 123HP and 170ft*lbs
WOW YOU FIGURED OUT WHERE I GOT MY INSPIRATION FOR THIS THREAD AND ENGINE SWAP !!! IF YOU NOTICE ...... I AM THE ONE WHO SUGGESTED USING THE DODGE DAKOTA BELL ( where i get basically ridiculed ) WHICH MOVED THE STARTER TO THE DRIVER SIDE OF THE VEHICLE AND AWAY FROM THE TURBO'S HEAT !! MY MACHINIST HAS SOME DIFFERENT IDEAS THAT MAKE THE SWAP GO EASIER AND COULD MAKE IT EVEN EASIER !!!
ANY WAYS ....... YOU WILL NOTICE THE THE USER " HULKGREEN " ON DIESEL BOMBERS IS THE SAME USER " HULKGREEN " ON THIS FORUM !!!
Also after researching it seems that " vlado " the original poster @ Diesel Bombers seems to have used the peugeot transmission bellhousing cause it looks absolutely nothing like my 94 Jeep AX-15 Bellhousing !!
Just finished converting my YJ to a TURBO DIESEL ..... want to see how .......http://www.flickr.com/photos/42246689@N06/ or check out my BUILD THREAD ......http://www.jeepforum.com/forum/f12/3-0l-mercedes-turbo-diesel-into-1994-yj-835449/
hulkgreen is offline   Reply With Quote
Old 08-24-2009, 08:35 PM   #79
91NDJeep
Great build idea....!
My bro-in-law is a Mercedes technician and the techs at the shop are always looking for good deals on 300Ds. They love them. My sis doesnt "get it" as she likes the new stuff but for the wrenchers...its widely respected as one the of the best engines ever.
Hope it works out for ya.
*Veritas Aequitas*
91NDJeep is offline   Reply With Quote
Old 08-25-2009, 08:07 AM   #80
73Dart
I have a 96 Ram 2500 Cummins diesel and pull down 18 city and 20-22 highway.
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar.
My motor swap thread
73Dart is offline   Reply With Quote
Old 08-25-2009, 08:11 AM   #81
UbelGeist
1978 CJ7
My 96 F350 7.3 diesel consistently 20-22mpg. That was with a 3.73 gear set and a manual transmission.
UbelGeist is offline   Reply With Quote
Old 08-25-2009, 08:20 AM   #82
Unlimited04
Unlimited04's Avatar
freakin' awesome man! can't wait to see how this looks when your done! those mercedes 3.0L's are bombproof and then some
Unlimited04 is offline   Reply With Quote
Old 08-25-2009, 08:46 PM   #83
h20squirter
i'm driving a 2007 GMC Sierra 2500HD, my Dmax is getting 17 around town and 19-20 on the highway. hell, towing a 10k trailer on the highway i still get 15-16.
Next Up is a 2012 JKU
97 Wrangler TJ SOLD
SkyJacker 4" suspension lift, 35" BFG MT, Front & rear Bumpers.
07 Wrangler X SOLD
SkyJacker 2.5" lift, Pro Comp Wheels, Mickey Thompson Baja MTZ 315/70R17's, Jet Power Module, Airraid Cold air intake.
h20squirter is offline   Reply With Quote
Old 08-25-2009, 08:49 PM   #84
levergun
levergun's Avatar
1979 CJ5
That truck must get beat pedal to the floor!!!! Most F350's w/ the deisel are capable of 22-23 regular driving. I got 18 on a 800 mile drive towing a 92 F-250 behind my buddies 06 F-350. My 90 cummins W-250 That is being used for my swap got 22 all day long w/ 35/s and towing a 5K hay trailer I still got 18-19!!!!!
1979 CJ5 408 AMC, Holley truck avenger 770, T15, Dana 20, custom ford 9" w/ strange axles, Dana 44 front, 8" of lift, custom fenders, Hedman headers, 36x14.5 MT baja
1988 YJ 4.0 FI, AX-15 5spd. NP231 4" RC lift 1" shackles 33x12.5R15 Firestone Destination MT Ford 8.8 w/ 4.10 gears no TB or SB
ASE certified Auto Tech
NRA lifer USNss
levergun is offline   Reply With Quote
Old 08-26-2009, 08:07 AM   #85
73Dart
When my truck was still an auto it would get 12-13 pulling 12k now with the manual it is pulling 14-15 pulling the 12k 5ver.
Old 08-26-2009, 08:55 AM   #86
50rck
How is someone only getting 11 mpg w/ a diesel? My 99 F250 7.3 got 23 once on a 5 hr trip. Mostly I got around 17 with a mix of heavy city and back road country driving. And that was w/ 33's. The 07.5 Durmax I have now gets about 12 to 14 pulling a 14k 5th wheel toy hauler w/ 2 Harley's. My rebuilt 91 Jeep 4.0 is now getting about 18 between city and country roads. But I drive that like a grandma, trying to get another 235,000 on it again.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 25,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline   Reply With Quote
Old 08-26-2009, 01:11 PM   #87
hulkgreen
Imagine driving your YJ like that and pulling down 32 mpg !! With the stuff I am selling off the left over Mercedes donor car ..... this ( including machining adapters ; not making them myself ) is gonna cost less than $1200 !!! But my buddy is bring over his portable welding machine to weld in the motor mounts !! SO; no cost there ..... just a couple beer and a few laughs between friends.
Hell it was gonna cost me more for a remanufactured long block at O'reilly than to do this swap !!
THe trick is to find a donor car to rob the small gidgets and gadgets from !!
Old 08-26-2009, 01:19 PM   #88
WCoon
Are you sure that is the Powerstroke and not the V10? If he has a V10 I could definitely see 11 MPG.
WCoon is offline   Reply With Quote
Old 08-26-2009, 02:40 PM   #89
Smithy
There's your problem, gas doesn't do too well in a diesel engine
I kid, I kid....
Brandon
Smithy is offline   Reply With Quote
Old 08-26-2009, 03:08 PM   #90
Ironworker709
Ole Ironhead
Ironworker709's Avatar
I have a 2000 F250 super duty 7.3 intercooled 4x4 with a hypertech II programmer and 4" borla stainless straight through muffler,no cat on a 2000 model,and a K&N filter,...got 18MPG towin the YJ on 12 hour trips,get 23 all day long no towing.
Ironworker709 is offline   Reply With Quote
Glock Forum
