#31 | |
I ran that thing for years and I will tell you it was great for what it was. I have years of experience with that motor. When you hit the gas it slowly takes off and then goes once the turbo hits. It will take a lot of clutch to get over any obstacle. You have no power until you hit about 15 mph. If you find the HP rating for that car it will show it as XX/XX without the turbo and with the turbo. There is a decent difference between the two numbers and it is very apparent when you drive it. You will either have to drive fast or keep the rpms up to get ANY power or keep the engine at higher rpms. If you have a stick you better get ready to replace clutches. I don't see it as a good choice for off-roading at low speeds. It takes time for that turbo to work. If you are running trials at higher speeds and you don't need power at lower speeds/rpms you will be fine. The 4.0 puts out a decent amount of torque and power at lower rpms, that is not how that engine performs and why it is a good choice for a jeep. It would be a terrible choice for a vet. That car was a great car to drive at higher speeds for great distances; I believe it even held records fot that. But around town and at lower speeds it had NO go.
I promise you will be very disappointed in that motor if you wheel at low speeds.
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
#32 | |
#33 |
I estimate after tuning the Bosch VE pump and a few other minor mods I will be in the 600ft. lb. no sweat- at about 1800-1900 RPMs. Also moving the governor so I can hit 3K. I love cummins. Thread will be started soon...... The thing I love most about the 6BT is the awesome low end torque. You can practically dump the clutch in first gear with the engine IDLING and it'll chirp the rear tires. Hit the throttle and it'll just spin them- Awesome lower end- and when the turbo hits at about 1200 hang on. It PULLS!!!! I have buddies that pull 14,000lb. trailers on the freeway all day. The only disadvantage is weight. It weighs in @ 1100lbs. But- I figure thats not to much more than a Jeep w/ a big v/8 huge winch and a plow. To make up for that I'm getting custom springs made and also reinforcing everything.
1979 CJ5 408 AMC, Holley truck avenger 770, T15, Dana 20, custom ford 9" w/ strange axles, Dana 44 front, 8" of lift, custom fenders, Hedman headers, 36x14.5 MT baja 1988 YJ 4.0 FI, AX-15 5spd. NP231 4" RC lift 1" shackles 33x12.5R15 Firestone Destination MT Ford 8.8 w/ 4.10 gears no TB or SB ASE certified Auto Tech NRA lifer USNss |
#34 | |
#35 | |
Sorry the Dakota bell is a DIRECT bolt to the ax-15 .... no adapter needed !!!
Just finished converting my YJ to a TURBO DIESEL ..... want to see how .......http://www.flickr.com/photos/42246689@N06/ or check out my BUILD THREAD ......http://www.jeepforum.com/forum/f12/3-0l-mercedes-turbo-diesel-into-1994-yj-835449/ |
#36 | |
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff RED JEEP CLUB MEMBER #494 |
#37 |
89-94 169 hp and 400 tq, 94-98 160 hp auto 215 manual both 400 tq, 98-03 180 auto 215 manual (i think) and 450 tq, 00-03 hp 300 hp 550 tq only avaible with 6 speed manual, 03-09 started at 305 hp and 550 tq and is now at 400 hp 650 tq for the pickup and 305hp and 550 tq for the chassie cabs. I know the 89-98 numbers are right I might be off on the later models.
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar. My motor swap thread |
#38 |
Are you having to build an adapter to mount the dakota tranny to the merc and what are you doing for a flywheel?
#39 | |
#40 |
Just a thought -- why not try to find 300D 6cyl engine out of W124 models? Or even 300TD? First one is rated at 113 HP and I know for sure it can deliver certain 400.000 without any kind of service except for oil / diesel filters..
Back in 1993. we bought this one as brand new.. ![]() Still one of my favorite cars up to this date.. EDIT: just seen the title.. TURBO DIESEL Anyways; W124 300TD (station wagon) still seems as better option ![]()
You can follow me.. but it's gonna hurt www.wettpunktracing.com Last edited by Incursorio; 08-14-2009 at 06:14 AM.. |
#41 | |
lost in the woods
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 . For those who have not figured this out I'm old school but can handle the new too. |
#42 | |
#43 |
These points are all true !! This engine takes some RPM to get moving !!!
IF you compare to the stock car it is geared with like 2.31 gear set......and takes some rpm to get going !!!! But if it is geared in the 4.10 area with a 4 to 1 transfer case ( trust me ) the rpm is gonna come up much quicker than in a stock cars gearing !!!!!! here is a toyota with the mercedes engine with better gearing ..... by the way it is the RED one with the 38 inch tires ...... turn up the volume to hear the turbo whine at the end of the video !! http://www.youtube.com/watch?v=vEgl5P-Ooew BUT ..... REMEMBER ....... I AM DOING THIS FOR A DAILY DRIVER TO GET 28ish Miles Per Gallon !!!! And maybe run a little BIODIESEL !!!
#44 |
YES !! I am building an adapter plate from Dakota BELL to Mercedes Block !! I am reusing the stock 4.0L flywheel and " modifying " it !!! Especially to drill it to fit the Mercedes crank !!
#45 | |
This choice is due to much research all pointing to the 1982-1985 3.0L 5 cyl turbo diesel being a slightly better choice for LONGEVITY .....even according to the Mercedes Mechanics on the Mercedes FORUMS !!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
