Quantcast 3.0L Mercedes TURBO DIESEL into 1994 YJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 3.0L Mercedes TURBO DIESEL into 1994 YJ
Old 08-12-2009, 09:34 AM   #16
xxxflhrci
That certainly looked like a nice car.
xxxflhrci is offline   Reply With Quote
Old 08-12-2009, 11:31 AM   #17
lwszabo
wow. that car looked awesome...I hope everything goes well!
lwszabo is offline   Reply With Quote
Old 08-12-2009, 12:00 PM   #18
Fernando
Fernando's Avatar
1987 YJ Wrangler
Originally Posted by stu1021 View Post
Actually, his 85 would be rated at 125HP and 170ft/lbs.
I have an 87 300D turbo. It is a 3.0 6cyl. and the factory spec is 145 HP and 195 ft/lbs. Since these older mercedes are mechanical injection, it is fairly easy to adjust fuel flow and with an adjustable dump valve you can adjust boost pressure as well. If you want to burn a little more fuel, you can easily up the power output.
I have owned the car for the last 12 years and my son now drives it to high school. It has close to 300k on it and still runs strong.
Certainly a turbocharged engine offers a whole lot of room for easy tuning and gaining a few more ponies by increasing fuel and boost, as long as you stay within the limits so nothing blows, it works perfect!
I was unaware of numbers for the 4 cylinder engine, I can see this thread becoming a monster thread!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline   Reply With Quote
Old 08-12-2009, 12:33 PM   #19
8nine-sahara
aww you know you could have done without ac.
I'm from lousiana and I just run with the Half doors. haha
jk nice build. looking forward to the progress
89 yj
06 lj
8nine-sahara is offline   Reply With Quote
Old 08-12-2009, 02:13 PM   #20
Cheebs
This looks cool ! I'm subscribed !
Cheebs is offline   Reply With Quote
Old 08-12-2009, 04:16 PM   #21
JFranko
JFranko's Avatar
My dad had one that I always drove around. Before it was really slow until the turb kicked in, but after, the car hauled ***. So I'm sure there's more that can be done to up the power.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline   Reply With Quote
Old 08-13-2009, 09:45 AM   #22
hulkgreen
Wikipedia shows it at 125 horse and 190 with the turbo charger and I intend to INTERCOOL IT !! Should help quite a bit ..... BUT I am only wantin it for 25 + MPG and making my own fuel ( possibly ) !!
I will probably not bump/BOMB it more than that as I have heard it shortens the life ( 700,000 miles is pretty much FOREVER !! )
Just finished converting my YJ to a TURBO DIESEL ..... want to see how .......http://www.flickr.com/photos/42246689@N06/ or check out my BUILD THREAD ......http://www.jeepforum.com/forum/f12/3-0l-mercedes-turbo-diesel-into-1994-yj-835449/
hulkgreen is offline   Reply With Quote
Old 08-13-2009, 10:47 AM   #23
levergun
levergun's Avatar
1979 CJ5
I don't know man, seems like a lot of work to me for a minor power upgrade from the 4cyl. From the 4.0 it would be a downgrade. Also- I don't know where you got your info on the 4BT but it is wrong.
First you don't need to fab a PS bracket or any bracket- the jeep lines go right to the stock pump. In fact the cummins pump is stronger than the jeep pump by a lot- plus you never have to worry about loosing a belt since it's a direct drive. And most earlier motors- Pre- 96 have a vacuum pump- they didn't go to hydroboost till then.
On my swap I went with the 6BT because stock they make 200 horses and 400ft. lbs. of torque- They average 750,000 miles and have been known to get 1,000,000 with frequent maintenance and care. Also the Bosch VE pumps can be tuned just by adjusting the pump and can make 300 HP/ 600 FP no problem.
But hey- whatever floats your boat- wish you luck. Looks like a good project.
1979 CJ5 408 AMC, Holley truck avenger 770, T15, Dana 20, custom ford 9" w/ strange axles, Dana 44 front, 8" of lift, custom fenders, Hedman headers, 36x14.5 MT baja
1988 YJ 4.0 FI, AX-15 5spd. NP231 4" RC lift 1" shackles 33x12.5R15 Firestone Destination MT Ford 8.8 w/ 4.10 gears no TB or SB
ASE certified Auto Tech
NRA lifer USNss
levergun is offline   Reply With Quote
Old 08-13-2009, 11:30 AM   #24
That1guy
2007 WK
You got a link to this 6bt swap?
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline   Reply With Quote
Old 08-13-2009, 12:13 PM   #25
MC_NickP
i want to see pics of it in your jeep and maybe some running videos as well!
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
http://www.jeepforum.com/forum/f22/mc_nickps-black-tj-build-1036334/#post9499802
MC_NickP is offline   Reply With Quote
Old 08-13-2009, 01:54 PM   #26
Ross
I had a 1984 300SD with that motor. That motor would SUCK in a jeep.
It has NO power until you get the RPMs up. I could never imagine trying to crawl over anything other that a speed bump with it.
Once the turbo kicks in the power is better but until then you have just barely enough to get the vehicle moving.
DON'T DO IT!!!!!!!!!!!!!!!!
My Mercedes did get close to 30 mpg and had close to half a million miles on the whole vehicle and about 30k on the rebuit motor. It wasn't any louder than many gas engines. It ran GREAT but the lack of power at low rpms would not mix well if you use your jeep off-road.
Even if you geared it down, once the turbo quicked in the power jump would be hard to perdict and adjust for.
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more
"If you aim at nothing, you will hit it every time."
— Zig Ziglar
Ross is offline   Reply With Quote
Old 08-13-2009, 02:57 PM   #27
smoothop
1978 CJ7
ROSS,
I own a 1982 W123 and it is quite respectable in terms of acceleration and speed. I am not sure about your experience but this motor was used in GWAGEN's around the world and they run just fine off and on-road. This is a very reliable motor that has tons of pep. There was probably something wrong with your vacuum system.
smoothop is offline   Reply With Quote
Old 08-13-2009, 02:58 PM   #28
everydayXJ
Ross, man... that's just brutal!
I think this is one of the neatest ideas I've seen on JF. Agree that the Cummins is a bad fit for a jeep, way too heavy.
My vote for coolest engine projects (as if anyone cares): custom diesel install like this, 5.0 ford, 4.7 stroker build
everydayXJ is offline   Reply With Quote
Old 08-13-2009, 03:17 PM   #29
levergun
levergun's Avatar
1979 CJ5
I'M gonna make a build thread sooner of later.......The motor mounts/ crossmember is in- tranny+ tcase are in- I need to finish the 12" stretch I'm also doins and put the Dana 60/70's under it but it starts right now.
NRA lifer USNss
Old 08-13-2009, 03:54 PM   #30
JFranko
JFranko's Avatar
Holy ****, I thought that was just a typing error, and you were just putting a 4bt into a Jeep, the 6bt is going to be sweet. I can't wait to see the build.
Glock Forum
