3.07 limitations - JeepForum.com
post #1 of 10 Old 10-24-2011, 05:45 PM Thread Starter
coupleofjeeps
3.07 limitations
Well I just got ahold of this 92 wrangler. I've been a GC guy for a long time, never built up a YJ, so I'm excited. Built up a 04 WJ over a few years. Anyway, on to this now...
Finding out from my build sheet that I've got 3.07 runnin the show. PO put a 2.5 rancho, TC drop, lengthened rear ds, and 31's on it. Leafs are nearly inverted, shocks are bad, so I'm thinkin a minor overhaul is in order.
I'd like to run something like OME 2.5, get another inch outa shackles, tj flares, then top it off with 33's. I'm in the Denver area, so I'll wheel a little, but this is a DD, no need to stuff up the fender regularly. Won't see extended highway use, but some.
Question then: What will the gears allow me to do?
Thanks in advance.
93 ZJ, 98TJ, 03KJ, 04WJ - SOLD
HIS - 92YJ - mildly built - oh the places we'll go...
HERS - 2002 WJ Overland
coupleofjeeps is offline
post #2 of 10 Old 10-24-2011, 05:52 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Cheapest way is to find some 4 banger axles and swap them out. That will get you 4.10's. You can also get a Ford 8.8 in 4.1o flavor and just the front axle out of the 4 banger. That will set you up for those 33's without an issue. The rear 35 is a weak axle, and not worth spending a dime on when 8.8's are as cheap as they are IMHO
Auto or manual, and assuming it is a 4.0.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 10 Old 10-24-2011, 08:40 PM
Apollo12227
I recommend changing gears ASAP but they will get you by. Believe it or not I ran 3.07's with 36's for about a year with my tf999 3spd. Now I have a ford 9" 4.56 and the same in the front. Just a word of advice though, go ford 8.8 out of a ford explorer, axle code D2 for 4.10 gearing, and as someone else mentioned grab a d30 off a Craigslist 4cyl YJ as it will be 4.10 as well. You simply won't be happy running larger than stock tires with 3.07's...
Apollo12227 is offline
post #4 of 10 Old 10-24-2011, 08:45 PM
BigDeaner
1987 YJ Wrangler
I have 3:07 with 33" tires. Sucks bad, I've only used 5th gear a couple times in the time i've owned the jeep. Bit of an overstatement but if I put it in 5th going down hill I swear i lose speed,lol. I agree with the 4:10's, that's what I've been looking for.
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
BigDeaner is offline
post #5 of 10 Old 10-24-2011, 09:43 PM
jeepyj13
I run 3.07s with 33" tires on the 4.0 and tf999 for almost a yr. Yeah it sucks but driveable. Need to regear to 4.10s
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #6 of 10 Old 10-24-2011, 10:26 PM
AnonymousD
I have 35s with 3.07s on my 4.0L and its fine for driving around town. On the highway it will cruse right under 70 MPH easily. I dont get on the interstate much, and if I do it for about 18 miles. I plan on upgrading to an 8.8 with 4.10 gears and a 4 cyl front end eventually.
AnonymousD is offline
post #7 of 10 Old 10-24-2011, 11:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I agree with the 4.10 and 35's. I had 3.07 and it was completely drivable with 31's but I needed the upgrade to something in the 4 range. If you plan on being offroad more than on, go 4.88. If half and half, 4.56. If it's all flat highway driving go 4.10. If you don't think any of that suits your needs go 4.10 with 4:1 TC. Best of both worlds!
Luck Favours The Prepared
Anticanman is offline
post #8 of 10 Old 10-25-2011, 12:03 AM
tankinyj
i run 31's on 3.07's. i will be re-gearing to 4.10s when i go SOA and 35's
2012 JK, 44s, rubi case, 37" PBRs, stretched 8"
Crush Orange Jeep Member #55
NYC Jeep Club
tankinyj is offline
post #9 of 10 Old 10-25-2011, 05:35 AM Thread Starter
coupleofjeeps
Im not sure I'll ever be happy switching from the 4.7 in my dubj
I am looking long term, as I have little time until summer. Hopefully some stocker yjs with the 4.10 will pop up in the next couple months. Things like that go quick in this area. That should be just a simple plug & play swap, right?
I cant swing the extra $$ just yet for 8.8 swap.
post #10 of 10 Old 10-25-2011, 08:01 AM
jhumphrey
If you're planning to go to 35" tires, you'd be a lot happier with 4.56 or 4.88 gears than 4.10s. 4.10s would be to underpowered for 35" tires. Just my .02 worth.
Currently, my jeep has 3.07 gears on 31" tires. Im in the process of swapping my d35 to an 8.8. I wrestled with what gear ratio and done a lot of research:
If you find a dana 30 from a 4 banger with 4.10s, great. In my area, they wanted more for them than what I could buy the r&p and have it installed in my axle for. Keep in mind, you'll need a different carrier (jeep had two for the yj: one for 3.73 and down (numerically) and 3.73 and up). I bought a used carrier off ebay that came complete with spider gears for around $50.
I read that 4.10s with 33" tires will work "ok", but I would suggest going on and doing 4.56s to cover yourself in the event that you want to go to 35" tires in the future. Thats what Im doing. I chose not to go to 4.88s because at that size there is just to little contact with the r&p that if you get the jeep bouncing you can break the r&p....from what I read anyway. Hope that helps. From what you've said, money is tight and I understand (trust me!). Im piecing mine together a part at a time to help costs.
Swapping your d30 with a 4-banger d30 is simple to do. The 8.8 takes some mod work (a lot of it you don't realize until you dive in and start researching). Its the little things that get you (and add costs)
jhumphrey is offline
Limitations of a 4-Cylinder TJ? xocsida TJ Wrangler Technical Forum 17 07-13-2012 06:23 AM
NP231? What are the limitations? bigmeangreen YJ Wrangler Technical Forum 10 07-11-2011 04:50 PM
4hi mechanical limitations. WheelinOK TJ Wrangler Technical Forum 7 02-11-2011 04:10 AM
Lifetime Warranty limitations? firefly JK Wrangler Technical Forum 4 03-08-2008 07:24 AM
Towing limitations white sox bill YJ Wrangler Technical Forum 2 06-19-2002 12:20 PM
