2WD Low install issue - JeepForum.com
post #1 of 15 Old 03-18-2014, 02:51 PM Thread Starter
thaduke2003
Okay- I'm just wrapping up my install of the Tera 2WD low conversion (and a SYE) in my NP231. I put everything back together, and I can't get the t-case to engage any gears. I'm thinking it's out of adjustment, but the adjusting rod is FROZEN. Is this the likely culprit, or did I screw something up?
I've done one of these in my JK, and that went smoothly, but this booger just won't give me a gear/range. Frustrating! Anyway, SYE install went well- hoping I NEVER have to deal with those awful snap rings again! Cheers- Mark W.
thaduke2003 is offline
post #2 of 15 Old 03-18-2014, 11:52 PM Thread Starter
thaduke2003
Wow- no views? Nobody wants to touch this? Mark W.
post #3 of 15 Old 03-19-2014, 12:03 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Did you flip the new fork over?
Luck Favours The Prepared
Anticanman is offline
post #4 of 15 Old 03-19-2014, 12:06 AM Thread Starter
thaduke2003
How do you mean? Install it upside down? Mark W.
post #5 of 15 Old 03-19-2014, 02:25 PM
Lemoore-on
I recall having to cut about an inch off the shaft when I did my SYE. Mine was a different brand J & B I think. There was a step to mesure it and I skipped it put it all together and could not shift it at all. Went back and re-read the directions and sure enough I needed to cut the shaft.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #6 of 15 Old 03-19-2014, 02:28 PM
jeepster93
jeepster93's Avatar
X2 on cutting the shift fork shaft.
I had to cut mine down too.
jeepster93 is offline
post #7 of 15 Old 03-19-2014, 06:05 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
shouldnt*** have to cut on a 94 though. the 91 case I had was too long, the 93 case was just right. are you bench testing it, or is it back in the jeep? it takes some uumph to bench shift them even when its together right. Also going to assume you didnt forget to put the mode spring back on :O
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #8 of 15 Old 03-19-2014, 06:33 PM
superj
Ruh roh. First time I opened a tcase, I ended up having to redo it once or twice. Forgot some little thing and then couldn't get a piece lined anymore
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 15 Old 03-19-2014, 11:41 PM Thread Starter
thaduke2003
Okay- I measured the shaft before I put it in, and it was dead nuts.
The case is back in the Jeep.
Mode spring is still in there
The adjusting link is utterly frozen, so I'm working on either making something up or finding another (har har!). I called Teraflex today, and they agreed that it's probably just out of adjustment. I'll keep fiddling and see what I find- Mark W.
post #10 of 15 Old 03-20-2014, 09:28 AM
Lemoore-on
Does the 2lo give you true neutral as well?
Mike
post #11 of 15 Old 03-20-2014, 12:24 PM
NHfireLJ
NHfireLJ's Avatar
Its an option when you buy the kit
EDIT: the 4:1 kit comes with the true neutral plate...the 2low is an option
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #12 of 15 Old 03-20-2014, 07:53 PM
Lemoore-on
Damn, I have the 4;1 sitting on my welding table waiting to get installed! Bummer, I should have called when I ordered it. I guess I can still switch it out. Thanks
Mike
post #13 of 15 Old 03-20-2014, 08:14 PM
NHfireLJ
NHfireLJ's Avatar
ARe you wanting the 2 low feature or just the true neutral plate? cause you have the plate now... nothing to switch out unless you want to 2 low feature
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #14 of 15 Old 03-21-2014, 11:04 AM
Lemoore-on
I looked this morning & there is no shift plate at all in the Teralow case that I got. I assume I would remove & re-use the one from the 231 case? I will be ordering the 2-low today and will ask about the tru-neutral option.
Mike
post #15 of 15 Old 03-21-2014, 12:58 PM
NHfireLJ
NHfireLJ's Avatar
Ok. my bad, guess its with the 2low kit.. Sorry about that
SOLD
YJOTM FEB 2013
NHfireLJ is offline
