2nd exhaust gasket in short time - JeepForum.com
post #1 of 3 Old 05-14-2002, 07:08 PM Thread Starter
my litte red yj
i just put a new engine(2.5) in the first gasket went at 3000 miles the 2nd is no to far behind(4000 now) as what i can see as soon as i put it too the floor to move up a hill fast that is all it takes it goes at the rear 2 exhaust port's near the fire wall??? do i need better header's, or a flowmaster muffler thanks to all who reply
my litte red yj is offline
post #2 of 3 Old 05-15-2002, 10:35 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Do you have a header or stock manifold?
If you have regular cardboard gaskets, soak them in water before installing them. For some reason, it works, and you won't blow it. Must make it seal off and compress better, being softer.
4wheeler4CJ is offline
post #3 of 3 Old 05-15-2002, 11:30 AM
ezgoing
ezgoing's Avatar
If your blowing out the exhaust manifold gaskets maybe try to find ones with copper inserts or crush rings in them (for lack of a better discription) they are a lot more durable then the standard gaskets.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
Short Exhaust aka Dump Pipe Jeepguy1977 TJ Wrangler Technical Forum 14 05-16-2009 08:01 PM
Running 35s (for a short time) ArrizX TJ Wrangler Technical Forum 20 01-26-2009 11:22 PM
04 Sport Sputtering/Stuttering....for short time only. Now is fixed Sparty TJ Wrangler Technical Forum 4 07-17-2008 10:55 AM
Exhaust manifold gasket loosens up over time? defleppardsg TJ Wrangler Technical Forum 8 07-14-2008 04:51 PM
Finally time to build up (short story inside) Zlake TJ Wrangler Technical Forum 17 02-14-2008 08:44 PM
