258 experts I need help, new motor no oil pressure - Page 2 - JeepForum.com
post #16 of 19 Old 05-24-2011, 02:46 PM Thread Starter
Old4X
1990 CJ7
From your posts, it appears you assembled the engine.
Did you use a factory service manual as a guide, or what did you use?
These engines (even when new) are supposed to have the main and rod bearings hand fitted, and this can only be done with plastiguage. There are procedures in the manual for adjustments as small as .0005 inch . The proper clearance and torque specs are there as well, and must be adhered to .
In one of your pics, it shows the rockers, pivots, and bridges chunked in a box, this is unacceptable as they are mated to each other and the pushrods as well once run. The push rods also should also go back on the lifters they ran on.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 19 Old 06-12-2011, 06:58 PM
johnnykind
Hey Everybody... thanks for all your help, pulled the engine again and went through everything... turns out I'm just dumb
after taking everything apart I found out that I did put the thrust bearing in the wrong place... and I did not put the galley plug back in that goes behind the timing chain... I went back through my Factory Service Manuel and 4 outta 5 pics showed that hole as being empty, in the 5th pic you cant tell if there is a plug there or not???
And the rebuild kit didn't come with enough plugs for the whole engine.... So my clearances are good just put in a new set of bearings and used a plasti gauge this time...now I have great oil pressure and the engine runs smooth and quite....now I just have to figure out what the hell that transmission noise in 4th gear is...guess its time to rebuild that one too....
thanks again to everybody for helping out this forum rocks!!!
johnnykind is offline
post #18 of 19 Old 09-07-2011, 03:02 PM
rksnow1
I know this post is a few months old now, but Im about to rebuild my 4.2 in my 88YJ. Do you have any suggestions, tips, or precautions to look out for. This will be my first attempt at rebuilding an engine. My Brother will be helping me and has rebuilt a few Mitsubishi 4cyl engines but thought i would ask the experts who actually rebuilt a few of the Jeep engines first...
Thanks in advance.
rksnow1 is offline
post #19 of 19 Old 09-07-2011, 07:15 PM
Hillbilly Jeep
personally... doin a rebuild is awsome.. b.c u know what u get when ur done... but on the other hand.. what i did was i bought a rebuilt from advance auto.. and i havent had any problems with it... back in 02 i think i bought it.. and i payed like 900 for it..but also got a discount but anyway just my 2 cents
Hillbilly Jeep is offline
low oil pressure , new jeep help , oil pump , problem
brand new motor no oil pressure my jeep is a money pit rodneyt YJ Wrangler Technical Forum 13 05-22-2011 06:39 PM
Low Oil Pressure on Older Motor... dwilliamsceg TJ Wrangler Technical Forum 8 08-31-2009 11:14 PM
Repaced 165k motor with salvaged 60k motor, dropping oil pressure? weslaine TJ Wrangler Technical Forum 10 06-09-2008 05:08 PM
OK experts... numnuts TJ Wrangler Technical Forum 3 04-19-2006 08:40 PM
OK experts... numnuts TJ Wrangler Technical Forum 12 04-12-2006 10:37 PM
