258 engine oil capacity - JeepForum.com
post #1 of 14 Old 09-22-2010, 11:52 AM Thread Starter
Reverb
Whats the capacity of the 258 in quarts? And is it the same as the 232?
Thanks
Reverb is offline
post #2 of 14 Old 09-22-2010, 11:57 AM
Opihi59
from here it gets rough
Opihi59's Avatar
4.2 and the 4.0 take 6 quarts
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 14 Old 09-22-2010, 11:59 AM
remmons
X2. quarts with filter.
Robert.
remmons is offline
post #4 of 14 Old 09-22-2010, 12:01 PM Thread Starter
Reverb
trying to compare 258 and 232 not 242.
Thanks
Reverb is offline
post #5 of 14 Old 09-22-2010, 12:08 PM
remmons
Thanks
Uh-huh. Same capacity. Just different displacements. Technically, they both hold five quarts plus 1 quart for filter. You will find the specs on page 1-A 23 in this link.
258_232 AMC Engines
Robert.
remmons is offline
post #6 of 14 Old 09-22-2010, 12:32 PM Thread Starter
Reverb
Cool - thanks to everyone who replied
Reverb is offline
post #7 of 14 Old 09-22-2010, 12:36 PM
mcmud
1983 CJ8
The 232-258 pan capacity is four qts. and the filter one qt. Total of five quarts.
The referenced chart is clear on the capacity...that reference to adding a quart is after the oil filter change.
mcmud is offline
post #8 of 14 Old 09-22-2010, 02:38 PM
remmons
I decided to do a little research into this matter. Guess what I found over on the CJ forums? Here is a thread discussing this topic.
http://www.jeepforum.com/forum/f8/oi...73/index5.html
I would say this to be safe. Start with five quarts of oil after your oil change. Run the engine for about a minute to check for leaks and to let the oil circulate through the engine and the filter. Shut if off, wait a minute for the oil to drain from the Cyl. head, then recheck your oil level. Chances are, you may need a sixth quart.
Robert.
remmons is offline
post #9 of 14 Old 09-22-2010, 03:52 PM
IP076
Originally Posted by remmons View Post
I decided to do a little research into this matter. Guess what Ifound over on the CJ forums? Here is a thread discussing this topic.
Oddly enough...I do just that...and usually end up good with just 5 quarts.
IP076 is offline
post #10 of 14 Old 09-22-2010, 05:54 PM
mcmud
1983 CJ8
Yeah ..I'm very familiar with that thread and others like it. It always seems that the consensus is more or less even.
The one mentioned list 11 responders who use 6qts., 4 or 5 of them fessed-up to the oil level being above the dipstick full mark. Then there are ten who use 5qts. Oh and one said that 7qts was needed.
Then one of them, a most respected/very active member, later reported the complications he had with oil leaks when he tried the 6qt. level. He went back to 5.
The amount is an age old question and will not be settled today nor tomorrow. One manual says this and one says that.
For example the Chilton list 5qts with the filter change while the Haynes list 6qts. The 84-86 MR252 states that 6qts are necessary "with or without a filter change" go figure...those were the most perilous and the waining years of the AMC era, the developers of the 232-258. There are many discrepancies in that manual, several reprints from previous manuals, most of them wrong.
The most thorough TSM manual that one can find covering the 4.2 standardized edition is the '81TSM. That was the first year after the '78-'79-'80 I6 changes and that was the build print that followed at least till '86. It list 4 in the pan and one in the filter a total of five. Any 4.2 user should have that manual not only for this topic but for total driveline management.
I went to the "Mopar Jeep Engines", a DaimlerChrysler publication, the finest performance engine manual that there is, IMHO. It refers back to and reprints the '81TSM..4+1 with filter change. It also refers to the '90 TSM, so I assume that there were some differences however I see no listing for the oil capacity in the reprint.
Having several jeeps with the 4.2(all CJ's) I would never skimp out on oil protection. All are to the full mark, all of them have 5qts of oil and none of them drip or rattle.
For the safest protection I always prefill the oil filter prior to it's install, it keeps that dry-start rattle away.
mcmud is offline
post #11 of 14 Old 09-23-2010, 10:15 AM
remmons
Thank you for telling us about the "Mopar Jeep Engines", a DaimlerChrysler publication. I will have to find one and get it ordered in. If there is anything I dislike, that is misinformation. I know and realize that a publication states that they are not responsible for errors or misprints, but when it comes to getting it right the first time, I want to be sure that the information is right.
Robert.
remmons is offline
post #12 of 14 Old 09-24-2010, 08:37 AM
mcmud
1983 CJ8
That manual will be an asset.
It covers in great detail the OEM maintenance and rebuild, performance mods, engine blueprinting and racing secrets, Lol.
Covering the 2.46L Hurricane, 2.5L Power Tech, the 4.2(258), 4.0L PowerTech, the 4.7 PowerTech V8 and the 360ci V8.
mcmud is offline
post #13 of 14 Old 10-23-2010, 09:42 AM
KJNewbs
1983 CJ7
Been looking for some info on the 258 and found this thread. The oil info was great, thanks! Can anyone shed some light on what the normal opperating temperature of the 258 should be? I need to determine if my gauge is shot or if my engine is running hot. I can get a Rad top with built in Therm, but need something to compare the numbers to. I'm hoping that there is a chart showing the engine temps, with relation back to the gauge. If I had that, along with the key 'proper running temps' I could diagnose my situation.
Can anyone help? Cheers!
KJNewbs is offline
post #14 of 14 Old 10-23-2010, 09:04 PM
yellow2kgt
My 90YJ with the 258 has always ran between 200-210. If I am climbing a steep grade for a long time it will creep up a few degrees more but it is almost always rock solid between 200-210 (this is with the factory gauge.) It has been that way for the past 6 years even after replacing a blown water pump and leaky rad with new parts.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
oil capacity 4.0 snofrog TJ Wrangler Technical Forum 10 05-13-2016 01:15 PM
try again-98 tj capacity? mmtphoto TJ Wrangler Technical Forum 6 04-08-2007 09:13 PM
Oil capacity of 8.8 sequel YJ Wrangler Technical Forum 6 10-15-2006 08:58 PM
AX5 capacity Flashman1 TJ Wrangler Technical Forum 1 03-20-2006 10:40 AM
4.0 oil capacity? ian-X TJ Wrangler Technical Forum 2 10-04-2003 01:15 PM
