258 Crankcase Vacuum Fitting - JeepForum.com
post #1 of 5 Old 07-23-2013, 08:56 AM Thread Starter
Hacken
1987 YJ Wrangler
Can anyone Explain what this vacuum fitting is for and/or what it should be connected to? I have not found it in any vacuum diagram. It is located on the drivers side of the block just below the freeze plugs in front of the motor mount. I am going to try to up load the only picture of it i could find on line.
Hacken is offline
post #2 of 5 Old 07-23-2013, 09:22 AM
Old4X
1990 CJ7
That is the CTO switch
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 5 Old 07-23-2013, 09:23 AM
roadyrob
1987 YJ Wrangler
how old is that motor? I'll take a WAG, it looks like a CTO port. your don't have one on your intake as it isn't water cooled so that must be it. can't tell you what it hooks to as mine is long gone.
late again! I've got to learn to type faster.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 5 Old 07-23-2013, 09:30 AM
Old4X
1990 CJ7
http://home.sprynet.com/~dale02/cto.htm
Old4X is offline
post #5 of 5 Old 07-23-2013, 09:35 AM
Old4X
1990 CJ7
That is an ancient motor. That vac switch works like the CTO, but is for the choke heater IIRC. You have the old married style intake and exhaust manifolds and there is a heat exchange tube (that rusts out and causes a bad vac leak) that hooks to the hot air tube to the choke coil. That vac switch shuts off the heat once the engine is hot enough.
The elect choke cap replace all that junk.
Old4X is offline
