231/300 Combo - JeepForum.com
post #1 of 26 Old 03-06-2007, 01:39 AM Thread Starter
doug_1994
doug_1994's Avatar
231/300 Combo
I never really wrote a full on writeup for my install. With the PM's Ive been getting, I figure I could put something together from the pics that I have. So here goes.
Getting the "kit". This is what I purchased from DD Machine (from here:http://www.pirate4x4.com/forum/showthread.php?t=451754)
Front plate (with Dana 300 clocking plate)
4340 shaft, 23 spline
Here is the NP231 that I had to buy (T18 and Dana 20 were in my YJ). Take the case apart. The back half can be pitched or sold. Then cut off the front lobe. I used a sawz-all. Used the "block off plate" as a guide (it comes in the kit).
Front.
Back.
Note: The shifting fork and collar are not needed, and a new shift rail is included.
Test fitting the front plate. to the NP231
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #2 of 26 Old 03-06-2007, 01:50 AM Thread Starter
doug_1994
doug_1994's Avatar
Block off plate ground down to fit.
All tigged in. I had a local propeller shop do it.
Here is the NP435 I used. It was from a '79 ford.
Novak adapter. http://www.novak-adapt.com/catalog/kit_431.htm
New main shaft.
Plato
post #3 of 26 Old 03-06-2007, 01:54 AM Thread Starter
doug_1994
doug_1994's Avatar
Tranny put together.
New length just under 14"
Mock-up together.
Total length, just under 22"
Plato
post #4 of 26 Old 03-06-2007, 02:00 AM Thread Starter
doug_1994
doug_1994's Avatar
The Dana 300
The clocking ring now installed.
Removal of the old T18 and Dana 20
Plato
post #5 of 26 Old 03-06-2007, 02:08 AM Thread Starter
doug_1994
doug_1994's Avatar
The old T18/Dana 20. Great tranny, but it was the 4:1 first.
Bellhousing from Advanced Adapter's. There are two more "adapter plates" still on the bellhousing. It was to "eat up" the long input shaft of the T18. A bellhousing from a T150 or T176 are the same as what I have. I did not know this four years ago when I did the T18 swap. It is typically known as the "butterfly" mount.
New conversion pilot bushing from Novak's.http://www.novak-adapt.com/catalog/p...htm#amcengines
Name:  pilot bushing.jpg
New clutch from Napa. (not sure of the part#) If I recall correctly it is a 10 spline, 10" disk.
Plato
post #6 of 26 Old 03-06-2007, 02:19 AM Thread Starter
doug_1994
doug_1994's Avatar
Old pressure plate from T18 install. It did have some heat marks, but I reused it anyways. I know some people will say I should of changed it, but oh well.
Name:  pressure plate.jpg
Tranny is in. The only PITA was getting the old pilot bushing out. Once it was gone she slid home pretty easy.
You can see my homemade slave cylinder bracket.
Tranny mount from Auto Zone.
All together now. I don't have pics of the skid plate install. I used the factory one, with some new holes drilled in it.
Plato
post #7 of 26 Old 03-06-2007, 02:29 AM Thread Starter
doug_1994
doug_1994's Avatar
The only gripe I had on the whole install was the lack of support for the rear of the 300, and no real direction on which way to go. The tranny mount was way far ahead, and I thought the rear should be supported. So I improvised and made my own mount, outta some old poly bushings, tube, and plate. I tied it into my fifth link mount. Not gonna win any fabbin' contests, but it works.
Plato
post #8 of 26 Old 03-06-2007, 02:52 AM Thread Starter
doug_1994
doug_1994's Avatar
With it coming up on a year, I still absolutly love it. The gear choice is amazing, allthough it did take some getting used to. Once I find the right gear, it is usually dead nuts on.
My gear choices are.
NP435~ 1st 6.68, 2nd 3.34, 3rd 1.74, 4th 1.00, and reverse 8.26
NP231~ 2.72:1
Dana 300~ 2.62:1
Axles (60,14)~ 4.10
Crawl ratio~ 195:1
Figure your own out here:http://www.novak-adapt.com/knowledge/gearing.htm
The total cost of this was some what manageable. I collected the parts for some time. Most of you prolly still have a NP231 in your jeeps now. Plus the fact that I had to adapt my tranny to the 231. So you are way ahead of the game.
The wheelbase was stretched to 110" using stock XJ springs all around. Also with some massaged perches.
Hope this helps, or open some eyes to the "double" lifestyle.
Doug
Plato
post #9 of 26 Old 09-06-2008, 09:27 PM
MAX_Xj
MAX_Xj's Avatar
i love the write up but my favorite part was the rachet straps through the floor to lower the tranny,
The reason why its so funny cause me and my friends did the same thing puttin my tranny in 6' peice of pipe, 4 pulleys, and some rope les the 20 minutes my tranny was in,
Nice write up btw
1998 4dr XJ
MAX_Xj is offline
post #10 of 26 Old 09-06-2008, 10:53 PM Thread Starter
doug_1994
doug_1994's Avatar
Damn, first reply 18 months later!
I hear ya on the home-made "tranny jack". When you do things by yourself, you gotta improvise.
Thanks.
Plato
post #11 of 26 Old 09-06-2008, 11:56 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
thanks doug!
i am about to get an xj, and considered the doubler route now i will have the wheelbase.
i can either do that, or install the atlas 4.3 i already have....
BTW, it already has a 231, and i already have a rebuilt 300......
opinions??
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #12 of 26 Old 09-07-2008, 12:16 AM Thread Starter
doug_1994
doug_1994's Avatar
^^^Your welcome Martin.
Hell, your got about all the hard parts allready.
I'd leave the Atlas in the YJ, and you may as well utilize that 300!
I guess it would all depend on your axle choice. I can't imagine stockers holding up to the deep gearing.
And, the 300 dumps to the passenger side, so that would need to be addressed. Flipped, or new front end.
Then you get into exhaust, gas tank(? maybe not in an XJ, dunno), driveshaft lengths, ect.
Whats the XJ gonna be used for?
Edit:
If the XJ is an auto (which I'm gonna guess it is) you may need to do something with the brakes also. I have a 60/14 front, and rear, with massive *** calipers, and drums. With this kind of gearing it pulls right through the brakes (1st gear,low,low). I have to push the clutch in to completly stop. But on the good side, I can about stall out, but still climb, at about 500 RPM with just riding the brakes.
Plato
post #13 of 26 Old 09-07-2008, 08:57 AM
leftlanetruckin
XJ on 37's
doug,
the yj is going mate, being traded for 2 xj's, 1 partially built. part of the deal is me keeping the atlas and dropping the 231c/j back into it.
i know all about braking problems, when i did the atlas in my junk, low range was about unstoppable. thats when i went with the dual diaphram booster.
700r4 + 4.3 atlas + 4.88's + 37's = cant stop on stock yj/8.8 brakes!!
stops fine now, finally...
and yeah, it is a 4.0 auto mate.
i can get the atlas in there for the cost of new input gear ($160), and then sell the 231 with sye. selling the old 231 will more than pay for the atlas to go in there IMO.
biggest i will go with it will be 35's. not decided on axles as of yet, but damn those jk rubi axles look like a good deal to me.
i was debating the (pretty much) new atlas vs the doubler arrangement already. will have to see what comes along i guess....
Martin
post #14 of 26 Old 09-07-2008, 09:19 AM Thread Starter
doug_1994
doug_1994's Avatar
With the stock AW4, atlas, and 3.55 gears (guess), you'd be at a 43 crawl ratio. With the 231/300 it'll bump it to a 71. Something else to chew on.
Plato
post #15 of 26 Old 09-07-2008, 09:24 AM
leftlanetruckin
XJ on 37's
gears would be 4.10 when the axles get done, or maybe 4.56, but i think the 4.0/aw4 with 35's will be happy with either one.
another thing to consider, it will be a semi dd for when the missus wants a change from the range rover, ok, when the kids wanna ride in the jeep then..... so looking nice n neat inside is a consideration too i guess.
decisions decisions......
martin
OME ZJ/LJ Combo done Crashnburn80 TJ Wrangler Technical Forum 16 04-03-2012 11:07 AM
4.10 and 4.56 bad combo? geewally9 YJ Wrangler Technical Forum 9 10-28-2009 01:52 AM
best buy on sye/cv combo jptaylor2 TJ Wrangler Technical Forum 2 04-04-2006 07:11 PM
this combo on my tj? 05willysTJ TJ Wrangler Technical Forum 1 06-30-2005 03:51 PM
anyone run this combo? paroxysym TJ Wrangler Technical Forum 3 03-15-2005 05:09 PM
