231 & 242 transfer case swap? - JeepForum.com
post #1 of 10 Old 11-13-2013, 08:21 PM Thread Starter
aheborn
Hi All
I am doing a frame-off restoration of a 1989 YJ Laredo. I have the 4.2L I6 with auto trans. I believe it's the TF999 tranny, yes? It's followed by a 2312 AMC transfer case which is completely shot. I have an '88 Cherokee with an I6 and it's followed by an 242 AMC transfer case (Quadratech?). Will they bolt up?
Thanks for all your help! These threads have been priceless.
Henry
1989 YJ frame-off rebuild. 1979 cj-5 project.
aheborn is offline
post #2 of 10 Old 11-14-2013, 11:04 AM
crackedcornish
if your auto tranny is stock, then yes it's a tf999
from the XJ FAQS:
NP242 = "Selec-Trac" part-time OR full-time - 2.72:1 ratio low range - shift pattern 2wd - 4part-time - 4full-time - N - 4LO - used 87-01
as I understand it, a cherokee trans has the t/c clocked differently than a wrangler, so you will have to drill new mounting holes to get it clocked correctly for your application
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 10 Old 11-14-2013, 02:26 PM
jeepguy85
1987 YJ Wrangler
from the XJ FAQS:
Or buy one of these and clock it with it....
http://www.pirate4x4.com/forum/motor...0-shipped.html
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #4 of 10 Old 11-15-2013, 07:44 PM Thread Starter
aheborn
I don't really know what "clocking it" means but I'll find out.
Thanks for your help both of you. I wonder if it would be easier to buy a junkyard one or a remanufactured one. Found one for $700 but seems like a lot.
Henry
aheborn is offline
post #5 of 10 Old 11-15-2013, 08:18 PM
jeepguy85
1987 YJ Wrangler
Think of the body of the transfer case as the hand on a clock. A clocking ring bolts between the transmission and transfer case and allows you to clock the transfer case by rotating the transfer case, usually in 10 degree increments, either up or down depending on the application.
post #6 of 10 Old 11-24-2013, 11:21 PM Thread Starter
aheborn
Sweet thanks
Henry
aheborn is offline
post #7 of 10 Old 11-25-2013, 10:21 AM
StanF
Look in my 8.8 swap thread below for my experience with a clock ring. It's in the Tummy Tuck section.
Short answer - I recommend redrilling the mounting holes in the transmission flange to the desired clock angle. It saves $75, and ensures that everything will seal properly. That being said, I did find the clock ring to be an awesome drill template
StanF is offline
post #8 of 10 Old 11-30-2013, 07:07 PM Thread Starter
aheborn
I found a transfer case attached to a 4.2 & tranny for $50! Dragged it out from the woods and proceeded to completely disassemble the transfer case & rebuild. Should be good now.
Henry
aheborn is offline
post #9 of 10 Old 12-01-2013, 08:24 AM
jeepguy85
1987 YJ Wrangler
That is a good deal. I paid $60 for the NP231 AMC I put in my 87. Good find!
post #10 of 10 Old 12-01-2013, 10:01 AM
fishadventure
My favorite kind of find! I got thousands of dollars of VW Beetle stuff for almost nothing whenever I had to drag stuff out of the woods
For the record- 'clocking' the transfer case is not big deal. Parts-shelf-parts-number dependency isn't beneficial, imho. Basically you locate it where it needs to be and drill new holes. Install bolts. Done. And $700 is a crazy price for a transfer case. I have two I would sell right now for that! Heck, at $700 I would take the t-case out of my DD and sell it. $100- $250 tops is what I see.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline
