2150 motocraft - JeepForum.com
post #1 of 5 Old 09-07-2013, 05:44 PM Thread Starter
toprope1
2150 motocraft
need an adpter plate to use this carb on my 84 4.2. need the throttle shaft to aim at the dist. thanks
toprope1 is offline
post #2 of 5 Old 09-08-2013, 06:51 AM
jr4x4
im in middle of building a 2150 to. advance auto mr gasket #1937 adaptor plate $20. and u need a felpro carb base gasket #60716. like $3.because from what im reading without it there will be a small vac leak in one spot of the adaptor plate.somewhere near one of the mounting bolts. good luck bro.. hope this helps you.
jr4x4 is offline
post #3 of 5 Old 09-08-2013, 05:19 PM Thread Starter
toprope1
Ok
what do i do? rotate the adpt. and drill the two mounting holes? thanks
toprope1 is offline
post #4 of 5 Old 09-08-2013, 06:01 PM
skyj
Why does the throttle need to face that way. Use the trans adapter plate #2086 from summit racing and adapt your throttle cable to fit it. There are lots of threads on this subject. I am just confused why you want to rotate your carb.??
build thread:
skyj is offline
post #5 of 5 Old 09-09-2013, 06:14 AM Thread Starter
toprope1
rotate
seems to make sense to me. also as seen on u tube. will check your other info. thanks
toprope1 is offline
