2150 or 2100 Carb Jet Size - JeepForum.com
post #1 of 2 Old 04-30-2007, 10:05 PM Thread Starter
Alabamaranger
Can anyone tell me what jet size they have on their 2150 or 2100 on their 258 6 banger? Not sure what mine are yet but it will not idle under 1000 RPM unless I run the fuel / air mixture in some. I checked for air leaks but could not find any.
Alabamaranger is offline
post #2 of 2 Old 05-23-2007, 08:02 AM
samahi72
I was told that 48's work best at sea level. There are actually two circuits to a carb. You have an idle circuit and a power circuit. The idle circuit is adjusted by the idle mixture screws. The power circuit is for higher rpms and the gas then goes through the jets. I am not sure what your problem is, but if you suspect a vacuum leak you can spray carb cleaner around the base of the carb and vacuum lines and then listen for the engine hesitating. That will help you identify any vacuum leak. Good luck to you.
samahi72 is offline
MC 2100-2150 installation DSawyer YJ Wrangler Technical Forum 7 02-11-2010 04:49 PM
MC 2150 and 2100 Parts Alabamaranger YJ Wrangler Technical Forum 0 11-13-2009 12:04 PM
Motorcraft 2100/2150 (?) carb. HELP! SamzJeep YJ Wrangler Technical Forum 10 11-11-2009 07:53 PM
2150 not 2100 help 1989 Islander YJ Wrangler Technical Forum 3 02-17-2007 06:03 PM
mc 2150 same as 2100??? USMC YJ YJ Wrangler Technical Forum 1 05-08-2006 12:34 PM
