203-205 doubler on an aw4 - JeepForum.com
post #1 of 4 Old 05-16-2010, 12:02 PM Thread Starter
boggerjeep
does anyone know if they make an adaptor to fit a 203 to the aw4..the 203 was bolted to a c-6.? and what would the length be compaired to the 231 that is now in it?
sell your home. buy a Jeep and a shop. cost about the same to have.
boggerjeep is offline
post #2 of 4 Old 05-16-2010, 12:48 PM
djsmith1174
I'm not sure about the adapter for an AW4, but it will definitely be too long for a standard wheel base YJ. Just lifting a YJ causes issues with driveline angles. Adding a second TC, even if it only adds 6" to the drive line length, would not be possible on a standard YJ. It would require the significant lengthening of the wheel base to get acceptable drive line angles. I'm not saying it's impossible, I know that it has been accomplished. You're just looking at some major modifications. Here's a link to a thread that describes the modifications with a Chevy SB and a TH350.
Offroad design 203/205 doubler - Pirate4x4.Com Bulletin Board
djsmith1174 is offline
post #3 of 4 Old 05-16-2010, 12:57 PM
dodger889
With a aw4 you lose about an 1.75 to 2 inches. they are that much longer. Then like said above any more length just make more work to get a good drive line angles.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 4 Old 05-16-2010, 04:58 PM Thread Starter
boggerjeep
i done some measureing today and i think your right on the extra inchs. but unsure about a adaptor to the aw4.
241/300 doubler kit? mcg311TJ TJ Wrangler Technical Forum 2 12-02-2009 09:26 PM
Anyone have a Doubler Transfer Case? JeepRocks86 TJ Wrangler Technical Forum 22 10-28-2009 12:58 PM
T Case doubler bizzle YJ Wrangler Technical Forum 13 05-02-2007 01:20 PM
more doubler ?'s Woodchk502 YJ Wrangler Technical Forum 21 03-24-2007 12:19 AM
231 doubler same length of 231 w/SYE rubberbelly YJ Wrangler Technical Forum 1 05-10-2006 03:36 PM
