E_ROCK
-YJ year of production
1993
-Specifications and modifications
Engine
Stock 4.0L
Transmission/Transfer Case
Stock AX-15 transmission
Energy Suspension poly Tranny mount
Atlas 2 speed with 5.0 ratio
Centerforce II Clutch
CV rear driveshaft
Custom made square front CV driveshaft
Front axle
Wagoneer D44 axle
Spicer 4.88 gears
ARB locker
CTM u-joints
USA Alloy 4340 Chromoly shafts
Custom Axle truss
Warn Premium lockout hubs
Ballistic Fab D44 knuckle gussets
Rockcrusher Diff cover
Spidertrax 1.5" wheel spacer
Rear Axle
Wagoneer D44 axle
Spicer 4.88 gears
ARB locker
TnT Axle truss
TSM Mfg. disk brake kit
Suspension - Custom spring over axle leaf spring suspension
Front
6" stretch with relocated steering box
Alcan springs using Ruffstuff spring hangers, custom thru the frame shackle hangers, and Ground Pounder Fab boomerang 3/8" thick shackles
Energy Suspension leaf spring poly bushings
Custom 1.5" DOM shock hoops
BBCS 11" travel gas charge shocks
2" Fox air bumps
Rear
4" stretch using GenRight Crawler gas tank
Ford Ranger bastard packs using Ruffstuff spring hangers, Ruffstuff Way Back shackle hangers, and Rough Country boomerang 3/8" thick shackles
Poly Performance outboarding shock kit w/ Ballistic Fab gussets
Bilstein 14" travel gas charged 5125 series shock (255/70 valving)
Modified MORE anti-wrap bar
Custom Timbren faux air bumps
Steering
Sky Manufacturing tall high steer arms w/ cone washers, and 5/8" stud kit
1.25" x 0.28" wall DOM with 7"-18tpi tapped ends
1 ton GM TREs
MORE steering box brace
Tapped Saginaw steering box for hydro assist
PSC 1.75" hydraulic assist ram assist w/ custom made mounts
Armor
Custom made 1.75" tube fenders
Custom made ¼" thick boatside rockers
Custom made Full 6 point, 1.75" tubing cage
Custom made 2"x4" boxed tube cross member bumper w/ build-in hitch and frame gussets
Custom made front 2"x4" boxed tube stubby bumper w/ custom winch mount
Genright Tub guards
Poison Spyder Comp Cut Crusher Corners with 3" tube flare
Custom made bellyup T-case skid plate
Custom made 1.75" tubing radiator hoop
AEV Oil Pan Skid Plate
Wheel and Tires
15" AR-23s (Spyderlock 17" 6061 T-6 aluminum wheels sitting on the garage shelf)
Seats
Yonaka Samurai Synthetic leather racing seats
RCI 5 point harnesses
Custom seat mounts tied to cage
Misc
Superwinch EPi9.0 winch
Sanden On Board Air
MORE 1" lift "Bomb Proof" Motor Mounts
Energy Suspension Body mounts
AAI Speed Equipment SS braided brake lines
Advance Adapters SS braided clutch line
Custom cold air intake tube by Hanksville Hot Rod w/ Spectre air filter
Mac Custom tie-down tracks in bed
Herculined interior
Grenade shift knob
CJ swingdown tailgate
40mm ammo can console
QuickFist for spare shaft storage
-Brief history of your jeep and how it came to be. (optional)
See my complete build thread
http://www.jeepforum.com/forum/f12/erocks-complete-build-1151311/
-Three pictures tags embedded onto entry
[IMG]http://erock.rockfrogs.org/Picture/2012_wheeling/Holy_Cross/HC_37.JPG
http://www.jeepforum.com/forum/f12/august-yjotm-winner-e_rock-1412971/?highlight=
