2000 wrangler parts on a 1990? (hard top) - JeepForum.com
post #1 of 5 Old 01-17-2013, 05:27 PM Thread Starter
keyloki
I have a descent 90 yj rag top and a friend of mine will let me have (for free) anything off of a bent frame 2000 wrangler that I want (except the tires) its going to the crusher. My 90 plows snow in the winter and I would LOVE to have a hard top w/doors when its cold. does anyone know if the hardtop and doors will transfer to my 90? Is there anything else I should take? I'm already getting the sound bar I dont know the model of the 2000 (JK, TK, Wk, whatever K) but it IS a 6 cyl like my 90.
TIA
keyloki is offline
post #2 of 5 Old 01-17-2013, 05:45 PM
Mark05059
take the hard top and doors.. sell them and buy the ones that will fit your yj.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 01-17-2013, 06:04 PM
YJ4LIFE
people have done it although i haven't seen a good thread about exactly how they did it. As the above said, the TJ parts are worth almost double the YJ parts.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #4 of 5 Old 01-17-2013, 09:45 PM
jmmorgan82
2009 JK Wrangler
They will fit with some work. Google "tj hardtop and doors yj" and you should get plenty of hits.
jmmorgan82 is offline
post #5 of 5 Old 01-19-2013, 05:42 AM
LilViper95
LilViper95's Avatar
To use the doors you would have to also use tj door strikers, this would probably require some mild fabrication. The top will more or less bolt on. You will need to grab the rubber seal from the top of the tj windshield frame. You then need to do some trimming to your ws frame to put the seal on. Pretty self explanitory when you look at it. Other than that just make a couple slotted cuts in the backside of your ws frame for the tj clamps to catch on.
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
