2000 Jeep wrangler, Blower Motor Problem? - JeepForum.com
post #1 of 2 Old 11-02-2011, 03:54 PM Thread Starter
isaacGI23
So here's the deal, I recently bought a 2000 jeep wrangler TJ and the guy I bought it off of said that originally the air only blew on the "high" setting , but that did not bother him because at least it worked. Then when I went to buy it off of him it had stopped working all together.
Here is what I have tried to do to fix it
Replaced Resistor located under dash on passengers side - Did nothing
Checked all fuses - All were fine - re-put them in changed nothing
Took the cover off the dash unscrewed the part that actually holds the switches/nobs that change the settings to check for loose wires or anything unclipped - there was nothing - unplugged and re-plugged - changed nothing.
Do you think I need to replace the Whole blower motor or what? Is there any way to check that the problem does infact involve the blower motor?
isaacGI23 is offline
post #2 of 2 Old 11-02-2011, 03:58 PM
iced98lx
Probably meant to be a section down
iced98lx is offline
2000 , a/c , blower motor , jeep , wrangler
2000 blower motor problem HELP buddha22 TJ Wrangler Technical Forum 2 12-11-2010 06:53 PM
Help with 2000 Wrangler Sahara Blower Problem ADH TJ Wrangler Technical Forum 20 11-23-2010 08:34 PM
Jeep 2000 blower motor kirk5291 TJ Wrangler Technical Forum 7 07-26-2010 07:35 PM
Blower Motor Problem- 1999 Wrangler ccoke04 TJ Wrangler Technical Forum 2 01-17-2009 11:14 AM
2000 wrangler with blower problem Drew968 TJ Wrangler Technical Forum 3 10-10-2007 08:36 AM
