2 part qs, 2.5-TB upgrade / oil in my airbox - JeepForum.com
post #1 of 9 Old 06-02-2010, 07:18 PM Thread Starter
kiitanak
so over the weekend i cleaned out my 4banger 2.5L TB filled with oil, nasty(*****!!!), also in the airbox.... ill get to that later.
so i know that most of u have upgraded to the 4.0 TB. i couldnt find a thread. what do i need to buy exactley? i diffently can use the extra power.
and... in the airbox, i have oil coming in from that hose that connects into the back section of the motor, where breaths from......
any help, sugg. would be cool. thnxs
kiitanak is offline
post #2 of 9 Old 06-02-2010, 10:42 PM
MJMPC
How many hose do you have comming off your valve cover?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 9 Old 06-02-2010, 10:57 PM
imstillatwork
You need the 4.0 TB. You swap over your 2.5 TB sensors onto the 4.0 TB, then bolt on. Although I would bore out the intake manifold to match the now larger TB, otherwise it could potentially be WORSE than before because you would essentially have a large wall that the air hits as it passes the TB.
The ford 19lb injectors spray a finer mist (atomize better) and are said to help a lot with the 4.0TB. I have not done either on the jeep, but have done similar mods to other cars and it's usually a bit more upper end power and more crisp throttle response.
imstillatwork is offline
post #4 of 9 Old 06-02-2010, 11:57 PM Thread Starter
kiitanak
now that u mention that, only 1. why r there some with 2???
wow thnxs for the info, i should be doing that mod in the next week, maybe this weekend. thnxs for the info.
those ford 19lb injectors, which car or truck do they come out of??
thnxs again
kiitanak is offline
post #5 of 9 Old 06-03-2010, 12:15 AM Thread Starter
kiitanak
the ford 19lbs inj. just slap in??? im guessing they do??
90-91 mustang, right??
kiitanak is offline
post #6 of 9 Old 06-03-2010, 12:54 AM
Dhofstet
1973 KK Liberty
What other info is available about the 2.5L to 4.0L Throttle body conversion is there? this sounds interesting and i would be willing to do it.
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #7 of 9 Old 06-03-2010, 02:22 AM
91BoD
Your CCV is plugged and your PVC could use a good cleaning or replacement.
The ccv is a brass plug located on the valve cover above cyl. 1 on the drivers side. Take it out, clean out the sludge, put it back in.
As for the 4.0 tb swap:
security torx are needed
all sensors must be swapped or replacement 2.5l sensor be installed.
There will be no benifit unless you bore the manifold to match the gasket
a 1-2" spacer is recommended for increase torque inprovements.
Reset computer and allow 30+ start run stop cycles. You may experiance erratic idel on first start up.
Injectors:
ford/bosh 19# yellow top injectors type 2 found in 5.0 mustangs type 3 in exploders.. Both work
without raising fuel pressure fuel delivery is actually .1# lower. Atomization is the main improvement.
Adjustible FPR:
only useful if you have done the above and possibly
headers, cam, 62mm tb instead of 4.0, etc
allows injectors to work at full potential
more pressure = more atomization = more power = more combustible fuel
electric fan
more responsive throttle
great cheap replacement for a toast clutch fan.
Last edited by 91BoD; 06-03-2010 at 02:24 AM. Reason: 4bangerJP.com is a great site for information on everything 2.5l
91BoD is offline
post #8 of 9 Old 06-03-2010, 07:10 AM
yoter
check out http://www.4bangerjp.com they have a write up on it
yoter is offline
post #9 of 9 Old 06-03-2010, 07:24 AM
jeepinmichguy_
you will not notice a difference in power by just doing a 4.0 tb.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
7 Blade Fan Upgrade Part Number SmackLayer TJ Wrangler Technical Forum 30 04-07-2012 09:42 PM
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 10:34 AM
Oreilly Part Numbers for Team Rush (TFI) Upgrade BumbleBee90 YJ Wrangler Technical Forum 0 12-31-2008 06:34 PM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 08:49 AM
Looking for HD Dana 30 axle shaft upgrade - need part number Mark_ZZ3 YJ Wrangler Technical Forum 5 02-04-2006 11:57 PM
