2 inch lift - JeepForum.com
post #1 of 7 Old 06-20-2010, 11:00 AM Thread Starter
Red_92_YJ
2 inch lift
Hi,
I am new to the jeep community, I have owned my Jeep for about 8 months now. I have a 92 YJ all stock. I am looking to put a 2-3 inch lift with 31-33 inch tires on it. It is mostly a daily driver, but i would like to do some off roading. I have been looking at the Tough Country 2 inch lift with shocks. I was wondering what else i would have to do if i put a lift on? I have read about SYE's and other such things but do not know if they r manditory with such a small lift. Any help would be much appreciated thanks.
Red_92_YJ is offline
post #2 of 7 Old 06-20-2010, 11:19 AM
Ptr
1992 J-Series Truck
I'm running the Rough Country 2.5" lift with 3/4" boomerang shackles. I've got about 4" of total lift right now. It doesn't look too bad with 31's, and it handles fine for DD purposes.
You may or may not get vibrations due to the drive shaft angle. I had some so i just put some washers between the skid plate and frame as a mini t-case drop.
Ptr is offline
post #3 of 7 Old 06-20-2010, 11:25 AM Thread Starter
Red_92_YJ
do the shackles help a lot? or were they just for extra lift?
post #4 of 7 Old 06-20-2010, 11:28 AM Thread Starter
Red_92_YJ
can i see a pic of your jeep? do u have any problem getting into it or do u have a step on your jeep?
post #5 of 7 Old 06-20-2010, 12:34 PM
Ptr
1992 J-Series Truck
I used the shackles to achieve the lift i wanted and to help prevent inverting my leaf springs
I have rockers on my jeep with a tube but I still have to kinda "hop up" into my jeep
This is the best picture I have, but I'll snap another side view of it soon
Ptr is offline
post #6 of 7 Old 06-20-2010, 01:03 PM Thread Starter
Red_92_YJ
yea i blocked my jeep up to simulate what the lift and tires would be like and its kinda in that zone where u almost need a step but you could live without them and i dont want them to hang down to much
post #7 of 7 Old 06-22-2010, 04:19 PM Thread Starter
Red_92_YJ
did u back space your tires at all? or do the 10.5 inch tires stick out enough?
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 12:15 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
