2 ignition options... what to do? - JeepForum.com
post #1 of 6 Old 02-28-2012, 09:21 PM Thread Starter
bluedaffy
My aftermarket ignition system (Jacobs electronics Energy Pak) has the option of being setup with something called OEM ignition or magnetic pickup ignition. I am going to do the nutter when I can figure out the answer to the question of which setup do I need to use?
The PO had the oem and until now that is what I have been running with the computer as well.
Can someone help me out as to which setup I should be using? keep in mind I need to know for the nutter bypass.
Also, the unit says it is an HEI ignition, if I switch to magnetic pickups will HEI ignition still be possible?
I apologize, I am very new to this. Thanks.
bluedaffy is offline
post #2 of 6 Old 02-28-2012, 09:27 PM
timatoe
timatoe's Avatar
You'll still use it on OEM after the Nutter and / or with the HEI.
timatoe is offline
post #3 of 6 Old 02-29-2012, 07:39 AM
Que89YJ
The HEI is not necessary for the Nutter bypass. Team Rush is the distributor Mod but IMO the HEI is a better design and if you are considering the nutter and have a few extra $$$ then do the HEI. together they make the biggest difference in how the the Old Girls run.
Que89YJ is offline
post #4 of 6 Old 02-29-2012, 10:46 AM Thread Starter
bluedaffy
Thanks for the replies. I think I'm more confused but that's probably a good thing because I would have probably done something dumb without your help!
So to make it a little easier for me to explain my current situation and to make it easier for you all to help me out (God willing) I took some pictures and labeled them to show you how my YJ is currently set up. Hopefully someone can help as far as what I need to do to nutter this baby! BTW- I know the wire connectors probably aren't a good idea to keep permanent but I tried to nutter her with the stock carter before winter and failed so I used them just to quickly reassemble so I could start it every once in a while during the winter months.
The first picture shows my Jacobs Electronics Energy Pak ignition module. Some literature (which is hard to understand) that came with the ignition from the PO claims that the unit can be used as either and OEM ignition or magnetic pickup ignition. The purple and orange wires that can be seen in the first photo are the magnetic pickup option and are currently disconnected and taped off. So I assume the 4 wires coming out of the center are the OEM option (whatever that means).
The second picture shows the purple and orange from the distributor to the purple and orange coming from the loom
The third picture shows what wires coming directly off of the ignition go to. Black and white from ignition go to tach, and the remaining two wires from the ignition hookup green(ignition)-green(loom) & red(ignition)-yellow(loom) as you can see it the photo.
I hope this helps someone to help me. I need to get that sucker nuttered up cause I just swapped carbs for a weber 32/36. Thanks. bluedaffy.
post #5 of 6 Old 03-01-2012, 06:25 AM
Que89YJ
Que89YJ is offline
post #6 of 6 Old 03-01-2012, 09:00 AM
wendell
1987 YJ Wrangler
You don't need to worry about the magnetic pickup option. On mine, I installed a CRT performance HEI distributor and a MSD off road ignition box. The good thing is that my CRT distributor came with a hookup for the MSD box, it was plug and play. This allowed me to do the regular nutter before installation. With you allready having the jacobs, not sure how you proceed. However, I would forget about the magnetic and consentrate on oem setup. Others I'm sure will have some more helpfull tips.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
electronic ignition , hei , ignition , nutter bypass
ignition randomly turns on after jeep is turned off and ignition locked karthac YJ Wrangler Technical Forum 3 01-12-2010 08:35 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
Questions about ignition wires and other ignition stuff Fernando YJ Wrangler Technical Forum 10 08-11-2009 05:33 PM
what options do I have? Mindvirus TJ Wrangler Technical Forum 2 02-09-2008 04:18 PM
I'VE HAD IT!! What are my options?!?! 92 Green YJ YJ Wrangler Technical Forum 14 09-15-2003 10:23 AM
