2" BDS lift and vibration...mpg? - JeepForum.com
post #1 of 3 Old 05-21-2001, 10:36 PM Thread Starter
SSJeep
Well, I did the BDS 2" lift...remember this is my daily driver...CJ is for fun.
My questions are...
-Is the increased vibration normal, and will it get better as it "settles in?"
-Why would my steering wheel be off-center now?...the guy told me to bring it back after 200 miles or so after everything settles...did he screw up or is this normal too?
-Any ideas what the lift and 31x10.5 tires will do to gas mileage in the HO 4.0L automatic?
Thanks so much,
SSJeep
SSJeep is offline
post #2 of 3 Old 05-21-2001, 11:41 PM
Razskidoo
I have a BDS 2" w/ 1" shackles and have no vibration!(even @ 75 mph )
Check and see if theres angle shims between the spring seat on the rear axle and springs. Is there a transfer drop kit installed?
And for the steering ,a drop pitman arm .
My steering is off location too, I don't fell any differents in the drivability or I'm just use to it! I'm planning to install one though.But not sure of dim. for a 3" lift?
Takeing it back after 200 miles is to retighten all hardware. (My U-bolts were loose after 100 miles).
92 Wangler ,I-6 ,3"lift, 32x12.5
Razskidoo is offline
post #3 of 3 Old 05-22-2001, 06:47 AM
smithbuiltYJ
I had BDS 2" lift put on by my local dealer @ 1 and 1/2 months ago. It gave me 3.5" of lift, and has not settled at all yet. I get a little driveline vibration. We did T-case drop, but not degree shims, as it said was not necessary on 2" lift. They said to bring it in in 350-500 miles to check tightness of everything. My steering wheel was off center, but still drove straight, they said the lift instructions said it might need to be re-aligned after the install, we did that, and wheel is back to center now. I'll be bringing it back in to check everything in about a week, so far everything seems ok. I have a 4 banger, and I put on 31x10.5" tires, my mileage (city) went from about 20 mpg, to 18 mpg.
Happy trails,
Marshall
'95 YJ, "Toy Story", some mods done, some mods on the way.
smithbuiltYJ is offline
2" Lift - Front Vibration/Knocking Issue After Lift cmorra68 TJ Wrangler Technical Forum 2 04-30-2009 10:12 PM
2" lift vibration? gumby885 YJ Wrangler Technical Forum 11 04-04-2008 09:16 PM
vibration after lift 2" White92YJ YJ Wrangler Technical Forum 5 12-04-2007 10:37 AM
Vibration after 4" R.C. lift? Atesjay YJ Wrangler Technical Forum 5 02-28-2007 01:01 AM
Vibration after RE 3.5"SF lift Vetteman TJ Wrangler Technical Forum 12 03-13-2006 06:47 PM
