Quantcast 2" BDS install writeup and pictures (long). - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2" BDS install writeup and pictures (long).
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 12-14-2004, 03:45 PM   #1
gc1155
(Scroll down for before and after pics - the after pic is a little dark. It was late when I finished. I sized the pictures so both shots are basically the same size and position. But the perspectives got a little messed up.)
I bought this '88 YJ from my brother-in-law who didn't really want to give it up. It had been parked for a while and he needed to get rid of it. After a well needed tune up, new vacuum lines and an EGR vavle it ran great!. Or at least well enough to drive from Pennsylvania to Texas to get it home.
You can see from the before pic that the stock suspension is in tired shape. Notice the rear leaf actually bends up to meet the axle. After trolling on the this forum for a while I decided to go with the 2" BDS box kit and 5/8" MORE shackes. The wheels and tires are a result of the fact that I'm pretty cheap, but it turned out looking nice. 15" Black Cragars and 31x10.50 Yokohama Geolander A/T's. The BDS kit and Shackles came from Bob Suplee in Oklahoma City. I'm in Fort Worth so he overnighted to my door and shipping was included in the quote he gave me.
A buddy of mine just bought a brake and muffler shop near by. So not only do I get steals on parts he lets me use his lift and airtools during off hours.
If you haven't done a BDS install then some of this won't make sense. But feel to ask questions if you're getting ready.
The BDS install took about 8 hours total, even with air tools. For the most part it went smooth with the exception of the inner spring eye bolts on both the front and the rear springs. The nuts came off fine but I beat on those bolts with a 5 pound sledge and they wouldn't budge. I ended up cutting the bolts flush with the spring mount, grinding them down, then prying the mount apart to drop the spring out. This probably added about 2 hours to the installation.
The front track bar relocation bracket was a sinch as was removing and installing the MORE shackles. The hardest part on the front aside from removing the old springs was relocating the break line mounting brackets. Not that it was real hard but cracking a 16 year old break line at 10pm on a Sunday would have completely ruined my night. I got it close enough to thread the nut and bolt through the adapter and drew it down from there. I was more comfortable with the steady slow pull on the line than me trying to yank that sucker another inch. If I had it to do over again I would add another hour to the installation and just buy longer soft brake lines and replace them. I would gladly sacrifice bleeding the break system out over stretching the existing hard lines.
The transfer case drop was pretty easy except those frame mount bolt holes were a little shady after all those years of Pennsylvania road salt. One mounting bolt was already broken flush, and one just spun and didn't come out. I ended up with two good mounts on each side, rather than the three. But I think it'll be ok.
The rear was basically the same only that the rear track bar relocation bracket was a little more difficult to install. It seems the BDS supplied bracket that is supposed to fit inside the original track bar mount is almost exactly the same width. I had to pry the original mount apart and hammer the BDS extension mount into place. Finally I had to use the supplied bolt to draw it in completely flush. Then it took a little more hammering to get the spacer bolt through. And that was it.
My only complaint is that the BDS kit didn't come with some hardware they assumed you would reuse. Normally this isn't a problem but if you're sawing off bolts don't expect to find replacements in the BDS box. Particularly shock mounting bolts and spring eye bolts. Luckily I was replacing the shackles at the same time and was able to use the old shackle bolts to replace the spring eye bolts I sheared off. It was late on Sunday, as you can see by the "after" pick, so going to the store for bolts was not an option.
I found out on the way home that my steering wheel is now rotated about 1/4 turn to the right. I suppose the suspension lift pulled the drag link over. A few turns on the drag link should fix it. I'm going to try and convince the guys at the alignment shop to do that before doing an alignment. I just don't feel like climbing under there for a while.
I get some vibration at idle, while not in gear. I'm pretty sure my transfer case mounts were bad to begin with, and the lift just made it worse. In gear and moving I don't get any vibrations. Compared to the old suspension and wheels the ride is pretty smooth.
I went with the 2" BDS lift and 31's because I didn't want to kill my 2.5l. But when I set the Jeep down for the first time I couldn't stop smiling. Compared to stock, it's huge! I had to go back and make sure it was actually the 2" BDS kit I installed.
Ok, here's some pics.
Parts:
Before:
After:
comments?
-gc1155
gc1155 is offline   Reply With Quote
Old 12-14-2004, 04:05 PM   #2
bono426
that lift makes your jeep look 10 times better! on a scale of 1-10 how would you rate this difficulty wise?
looks good
charlie
94 YJ 6cyl Auto some mods. sold
99 TJ Sahara 2.25" bb 33x12.50 BFG AT's. sold
2003 BMW 325i sold
2001 TJ Sport Stock for now
bono426 is offline   Reply With Quote
Old 12-14-2004, 04:12 PM   #3
gc1155
looks good
charlie
Thanks, I have to get a daytime picture and post it up.
Aside from being able to cut off the old springs (if the eye bolts are stuck) there's no special skill required other than turning a wrench. So I would say '6' only because it's a fairly long process that involves prying on things that are hard to get to, bloody knuckles and mild cussing. Having access to a lift and the right tools helped a ton.
-gc1155
Old 12-14-2004, 04:25 PM   #4
Macabre
1990 XJ Cherokee
It looks awesome. Great work!
You might remember, you almost bought my 2" BDS about three months back. I still haven't got it installed yet. But writeups like this, and sentinal02's, will make it that much easier when the time comes. Thanks!
HRJA.org
PGH-OFFROAD.com
1990 XJ, 2-door, 4.0, AW4, NP231, 3" lift, 32x11.5 Interco SSR's. 104,000 miles.
Macabre is offline   Reply With Quote
Old 12-14-2004, 05:43 PM   #5
phlex234
ditch the rear trackbar and make the front disconnectable
[SIZE=2][B]HI, my name is phlex234 and i approve this message because it's my destiny[/B][/SIZE]
[B]Jeep 2.5 Low Output club member #2
92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder[/B]
[URL=http://www.jeepforum.com/forum/showthread.php?t=155355]NEVER FORGET[/URL]
phlex234 is offline   Reply With Quote
Old 12-14-2004, 06:14 PM   #6
gc1155
I've been reading up on the trackbar disconnect. But I don't know how much wheeling I'll be doing just yet so I'll probably hold off. I think I saw a quick disconnect kit but I don't remember if it was for the track bar or the anti-sway bar. So far the Jeep is just my weekend beater/grocery getter - but I'm working on that.
Thanks for the compliments.
Old 12-14-2004, 06:16 PM   #7
max3k
Before pic looked like it was missing something.
Maybe something like this
I like your after much better...
Great Job!
'88 YJ 4.2 5sp - Black w/ Black Sailcloth Top.
RE 4" Lift
Cragar 352's 15x8 on Goodyear MT/Rs 33x12.50
Bushwacker cutout pocket flares
PORC Rock Sliders
Big Daddy Front and Rear Bumper/TC
JKS Quicker Discos
Tom Woods CV Driveshaft w SYE
Yukon HD 456 gears
XM Radio
Cobra 75 WX ST
48" Highlift
Lifted, Locked, and ready to Wheel!!
Hello,
My name is max3k and im a jeepaholic
max3k is offline   Reply With Quote
Old 12-14-2004, 06:24 PM   #8
phlex234
disconnecting swaybars is what your thinking of, but you can make one for front trackbar for like 5 bucks, the rear one you wont notice the difference. but i have BDS as well and your gonna love it, and its good you do this cuz it helps out peopel who are new, kudos to you
Old 12-14-2004, 06:39 PM   #9
gc1155
Ha! Rollin' on dubs! Where's the spinners man?
On a side note: Any reason why when I preview my post the before and after pics show up embedded (like yours). But when I actually go to the post in the forum they show up as links? I used the IMG tags.
Old 12-15-2004, 03:41 PM   #10
RAYMAN975
RAYMAN975 is offline   Reply With Quote
Old 12-15-2004, 04:35 PM   #11
gc1155
Originally Posted by RAYMAN975
here you go
Thanks! I now enjoy having to climb into the Jeep rather than falling down into it.
So what did I do wrong with the images?
When I prevewed they showed up, but after I submitted they showed up as just links.
Old 12-15-2004, 04:46 PM   #12
phlex234
hey rayman you need the 5/8 one to clear any military wrap
Old 12-15-2004, 06:11 PM   #13
Upstate Chili
Looks GREAT How much lift did the 2" BDS give you?
Upstate Chili is offline   Reply With Quote
Old 12-15-2004, 10:15 PM   #14
RAYMAN975
Old 12-16-2004, 08:19 AM   #15
JayJEEPguy
You didn't do anything wrong. You just need to be here long enough, + a post count of over 50, I think.
Looks good.
Jason T.
'05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote
Glock Forum
