2.5l yj power steering pump removal procedure? - JeepForum.com
post #1 of 7 Old 01-18-2012, 10:26 AM Thread Starter
yjwadley
Ineed to remove the power steering pump an bracket to get to the exhaust man. bolt hole in the front of the head. the previous owner either sheared it off or forgot to put it back in. the gasket looks to be there still so I need to put a bolt in and hopefully it'll thread if not I need to try and drill it out and use an e-z out on it, or drill and heli-coil it. I've done this before, but it's not the easiest thing to do . If i can stop the leak with not taking the whole intake and exhaust manifold off that would be great. any tips on this would be welcomed. but first of all is gettin the pwr. st. pump and bracket out of my way.
yjwadley is offline
post #2 of 7 Old 01-18-2012, 10:50 AM
yoter
take off the pwr streering pump n see if u can get a tap in there b4 you go thru all that trouble
yoter is offline
post #3 of 7 Old 01-18-2012, 05:04 PM
nembudonna
Fill out your profile. I have no idea what year or engine your talking about.
nembudonna is offline
post #4 of 7 Old 01-18-2012, 05:24 PM
jmmorgan82
2009 JK Wrangler
I sure hope you guys are posting from your phones. To answer your question, I did a quick Google search and found the following link: PS Pump Replacement Link. It is for a TJ but should be similar if not the same.
jmmorgan82 is offline
post #5 of 7 Old 01-18-2012, 06:01 PM
nembudonna
Why do you hope we're posting from our phones?
post #6 of 7 Old 01-18-2012, 08:50 PM
jmmorgan82
2009 JK Wrangler
Because those first two posts were brutal to read.
post #7 of 7 Old 01-19-2012, 07:47 AM
nembudonna
I got ya. I hate when people do that crap.
Remote Power Steering pump to XJ pump write up. bigredcherokee YJ Wrangler Technical Forum 0 08-16-2010 08:37 PM
Power Steering pump leaking pink liquid - can the pump be fixed, or replaced? Sparty TJ Wrangler Technical Forum 10 01-13-2010 10:29 PM
Power steering pump and bracket removal scbasspro YJ Wrangler Technical Forum 1 06-07-2009 03:03 PM
Leaky Power Steering Pump and Steering Clunk. KATSTJ TJ Wrangler Technical Forum 6 01-03-2009 05:03 PM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
