2.5l Sputtering. Bad Fuel Pump? - JeepForum.com
post #1 of 4 Old 04-12-2010, 12:01 PM Thread Starter
RockShoxTora
Alright so here's the deal.
When driving in the Jeep, I've noticed that it's starting to sputter.
As I get up to speed, the Jeep will act like it's low or out of gas. It jerks and sputters a little until i put it in neutral and pump up the RPMs. Then it behaves, but only for a little because it'll start to do it again.
On the highway it does it too, however not as bad. Maybe once or twice at a time.
But everytime it does it, it feels like I'm out of gas.
I read up and some people said the CPS, TPS, wires to the fuel pump, fuel pump, fuel filter, Rotor cap, wires, sparkplugs, etc.
I replaced my TPS last summer. I haven't touched my CPS, but is that even a feasable option? I'm not even sure was purpose that sensor serves.
I also replaced my fuel filter less then a year ago.
Replaced the sparkplugs less then a year ago, replaced the rotorcap when I bought the Jeep two years ago, and the wires are nice aftermarket silicone wires.
And as for the fuel pump, what I'm experiencing, are those symptoms of a failing fuel pump or frayed wires to the fuel pump?
The Jeep always starts up fine.
The fuel pump has no problem priming the engine with gas.
It only happens when I'm actually driving.
Thanks,
-Brian
1995 YJ
-3.5" Black Diamond Suspension Lift, Skyjacker Hydro 7000s
-1.25" Body Lift
-Trail-Gear Bumper and Tire Swing-Out
-31" BFG M/Ts KM
Square Headlights Member #751
RockShoxTora is offline
post #2 of 4 Old 04-12-2010, 12:12 PM
EABiker
Try pulling and cleaning your injector, and cleaning the throttle body, (get new injector O rings first!), along with changing the fuel filter. Also, Ohm out the IAC and coolant temp sensors to make sure they are reading the correct value for their temperature range.
EABiker is offline
post #3 of 4 Old 04-12-2010, 12:13 PM
Que89YJ
Could be a few things. Start by checking the fault codes. If you dont have and codes set then I would start by checking the fuel pressure at the rail. Also possibly a bad temp sensor. No the CPS will normally work or not work. When it doesnt work the engine will just cut out.
Que89YJ is offline
post #4 of 4 Old 04-13-2010, 05:28 PM Thread Starter
RockShoxTora
Thanks for the help everyone!
All sign pointed towards a failing sensor, so before I decided to bust out the ohms reader, I decided to take the easy path and seafoam throught the throttle body again.
Long story short, it fixed the problem!
I noticed there was quite a bit of oil and grime in the throttle body body along with oil residue around the small tube that connects from the airbox to the engine valve cover.
So I cleaned the tube out and throttle body with the left over sea foam.
Engine runs nice and strong now
Thanks for the help!
-Brian
1995 YJ
-1.25" Body Lift
-31" BFG M/Ts KM
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
Engine sputtering at low RPMs and loss of fuel mileage Scova TJ Wrangler Technical Forum 5 10-20-2006 04:59 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
Sputtering like it's out of fuel!!! aagongora TJ Wrangler Technical Forum 7 06-04-2004 02:36 PM
