#1 | |
2.5L Runs Fine Until...
My 95 Wrangler 2.5 runs fine until I plug in the O2 sensor. Then it bucks and kicks after a while. Unplug it and it runs fine on default. It's a new O2 sensor. It didn't have one hooked up when I got it. Thoughts?
1995 YJ, 2.5L, RE 4" lift, 0" Body lift, JB SYE, Woody shaft, FoMoCo e-Fan, 4.0 TB, 19lb Ford Style 3 Injectors, American Racing Bajas, 33" Toyo A/Ts /l , [____], l---L--[]lllllll[]- ()_) ()_)==@=)_) |
#2 |
No one?????
#3 |
You got a bad 02 sensor maybe? Oh it's new.. wow that is weird. Electrical problem then I guess.
AX5/NV3550 Conversion Thread. http://www.jeepforum.com/forum/f12/nv-3550-4-angry-squirrels-752742/ Bow Hunting www.bowsite.com For sale [http://www.jeepforum.com/forum/f126/ax5-bell-housing-conversion-external-slave-1298278/ |
#4 |
O2
Replace the o2 sensor with the ignition off, do a battery reset. Computer has a adaptive memory and it may be the memory effecting your stored calibration.
#5 |
What kind of O2 sensor? A lot of people have had problems with the Bosch O2 sensor which for some reason is about the only kind that must discount auto parts places want to carrier in-store. I have heard Denso has a good one.
#6 |
It's a Borg Warner sensor...I've used them before with no problem. As for resetting the PCM, Just leave a battery cable off for 30 seconds right?
#7 |
Battery reset
A long 10 count will do it....1 Mississippi........2 Mississippi
#8 |
just try and use another one I work at a parts store and i see those things come back defective every now and then
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
