2.5L more HP? - JeepForum.com
post #1 of 10 Old 02-02-2013, 10:29 AM Thread Starter
OliverTwist
2.5L more HP?
Hello, I have a 92 YJ with the 2.5L and was doing some reading an saw that if I add a a throttle body and spacer off a cherokee and and a cold air intake I could boost up the HP a tad. So what would I look for in the parts so I know they would work
OliverTwist is offline
post #2 of 10 Old 02-02-2013, 11:09 AM
Que89YJ
Try this web site:
http://www.4bangerjp.com/forums/
Everything you wanted to know about getting more HP out of a 2.5L
Que89YJ is offline
post #3 of 10 Old 02-02-2013, 02:50 PM
Jay-P
Put your money towards a regear...
But if you must... a 4.0 tb is a good idea, i personally wouldnt bother with a spacer, i have one and felt no difference. Add a free flowing exhaust and thats it. I wouldnt bother with a header. You have to watch that you dont shift the power band too high in the rpm range. Having to rev the crap out the the 2.5 to get those 5 added hp doesnt make any sense in a YJ.
1992 YJ + 2012 JKUR
Jay-P is offline
post #4 of 10 Old 02-02-2013, 03:30 PM
Mark05059
add 4 more cyls
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 10 Old 02-02-2013, 04:41 PM
ashland82391
ONE WORD.......NOS!!!!!!!
ashland82391 is offline
post #6 of 10 Old 02-02-2013, 06:37 PM
Xpress
Not a whole lot can be done, but what can be done has to be done altogether to increase power output. Not one single component or upgrade will yield a lot of power. The simplest way to get 5-10hp (or rather gain it back) is to go with an electric fan rather than use the factory steel fan. That's the biggest HP gain, unfortunately. The most I've seen someone get out of their 2.5L is about 40hp, but that was with close to a thousand dollars in components. For about $1500 you could swap in an entirely new driveline and be done with the 2.5L.
Or you can get used to driving a 4 cylinder powered brick. It has enough guts to mosey along at 65mph, even on stock gears with slightly bigger tires. Too big a tire will eat up your engines power really quick.
All about that unibody life.
Xpress is offline
post #7 of 10 Old 02-02-2013, 06:48 PM
Flood
I got more HP by selling it and buying a JK ....But seriously consider re-gearing since your on 33's. That was my plan, but I has to sell it, no room for both.
2004 TJ Rubicon: Khaki, 2 inch BDS on 31's.
2013 JKU Sahara: 6spd, Billet Metallic (Family Hauler/Mall Crawler for now...)
1994 YJ: Blue, 4cyl, 3.5 lift, 31's - Sold
Flood is offline
post #8 of 10 Old 02-02-2013, 06:51 PM
flcracker
I went with an electric fan to free up a little power but I am not sure how much power I gained.... seeing some improvement in MPG though so I guess it helped a little....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #9 of 10 Old 02-03-2013, 01:36 AM
nembudonna
It is what it is and that's all that it is. Save your money and be glad that it runs good.
nembudonna is offline
post #10 of 10 Old 02-03-2013, 04:47 AM
91BoD
You need to increase displacement or rpm. Not much else is very effective as others have mentioned.
91BoD is offline
