2.5L Exhaust Manifold - JeepForum.com
post #1 of 7 Old 02-13-2012, 09:45 AM Thread Starter
slimer74
I'm looking at new exhaust manifolds for my overworked & underappreciated '89 four cylinder that has a crack.
Most of the manifolds for sale are traditional manifolds, but a few have an extra port on the tube coming from the #1 cylinder. What is that port supposed to do?
My manifold has a heat shield with a port in the same location that connects to the air box via a flex hose. It's supposed to route heat from the exhaust manifold to the air box, I think.
Main issue: I want to confirm that I need the traditional manifold, should I buy a new one, not the one with the port in the #1 exhaust tube.
Any advice / education is appreciated.
slimer74 is offline
post #2 of 7 Old 02-13-2012, 11:47 AM
Que89YJ
The 87-90 2.5L have an EGR and the tube is for the EGR. I don't know what emission laws you are dealing with in Va. but if you want to save a few $$$ then you can flange off the egr and run the newer exhaust header. The ones with the egr tubes are expensive!
Que89YJ is offline
post #3 of 7 Old 02-13-2012, 02:32 PM Thread Starter
slimer74
QUE89YJ,
Thanks for the reply. Does that mean that I should have the manifold with the tube that branches off for the EGR or is the port only supposed to be on the heat shield as in the pic below?
Other than just doing the right thing with my repairs, I am moving to California in June and will have to be in strict compliance w/ the emissions to keep my Jeep on base.
slimer74 is offline
post #4 of 7 Old 02-14-2012, 11:25 AM
Que89YJ
Nope you need one with the EGR tube. It has a hole for the stainless tube in the front of the manifold. They are way more expensive unfortunately and you know you will need to meet Cal. emissions so you need it. Mine is a Borla.
http://www.quadratec.com/products/17601_03%2007.htm
Que89YJ is offline
post #5 of 7 Old 02-14-2012, 11:26 AM
Que89YJ
The pic is a stock manifold not the Borla. They run just under $200 while the Borla is over $400
Que89YJ is offline
post #6 of 7 Old 02-14-2012, 01:03 PM
sotomajr
Ebay is your friend
I just bought one on eBay for my 1995. It is universal, and had the port on the side. I had to put a cap on it for it to work on my 2.5L....and it was 80 bucks shipped
sotomajr is offline
post #7 of 7 Old 02-14-2012, 01:04 PM
sotomajr
sotomajr is offline
Changing intake manifold and exhaust manifold Gaskets Cards89YJ YJ Wrangler Technical Forum 17 01-13-2012 04:32 PM
Intake manifold and Exhaust manifold/headers Esco YJ Wrangler Technical Forum 5 10-17-2011 08:20 AM
Exhaust manifold/exhaust pipe gasket tashley YJ Wrangler Technical Forum 3 01-27-2011 03:28 PM
4.0 exhaust manifold barracuda TJ Wrangler Technical Forum 8 03-05-2010 12:01 PM
Upgraded head, but changed Exhaust Manifold so how do I get an exhaust system now? jeepdude1987 YJ Wrangler Technical Forum 2 02-18-2009 11:54 PM
