2.5L Belt routing with York compressor +PS and no A/C - JeepForum.com
post #1 of 5 Old 08-03-2012, 01:21 PM Thread Starter
matrix311
Hello,
I'm just finishing my on board air system and I have a question about belt routing. I routed it a little different then what the kilby website shows. Is this a problem or should it be mounted the way the kilby diagram shows? I dont want to be out on a trail in the middle of know where and snap a belt. I'll be having my old serp belt with me until i know this is proven. But any feedback on the belt routing is appreciated.
The way I have it right now seems to work. I'm able to run the Jeep the way it is and it moves everything and the tension is tight.
Here is how I mounted it.
Uploaded with ImageShack.us
Here is how Kilby has their photo belt routed
Eric - *'92 White YJ, 4.5" custom Deaver springs, 35" MTRs, Tera-Low 4:1, CAI, Rear 8.8, Chromo D30, 4.88s, locked front/rear, full cage and front/rear tube fenders.
*'08 Silver Rubicon JKU 2.5" lift, 5.13's and 35's
matrix311 is offline
post #2 of 5 Old 08-03-2012, 01:28 PM
Jeepguy84
I was actually wondering the same thing.
Mine's all mounted just was wondering that one thing.
Jeepguy84 is offline
post #3 of 5 Old 08-03-2012, 01:37 PM
SkyHigh
On my first 97 TJ, I routed it like Kilby did. I guess I am unsure why you'd attempt to change a proven routing method.
I see no reason why your way would not work, but I'd feel better running mine like Kilby does...cause its the norm.
- 97 Sahara -
- 13 Grand Cherokee Trail Hawk Hemi -
SkyHigh is offline
post #4 of 5 Old 08-03-2012, 01:57 PM Thread Starter
matrix311
ok thanks, i may try to get a longer belt and do it the kilby way. Just seems the belt will be so close to touching when it makes the bend around idler pully by the york and the fan.
post #5 of 5 Old 08-06-2012, 10:51 AM Thread Starter
matrix311
well i ended up getting a longer belt and everything looks good. I went with a 103 5/8" belt from NAPA and that seems to be the magic number. OBA is now completed!
converting a York v belt pulley to serpentine belt Dre40 YJ Wrangler Technical Forum 8 03-07-2016 12:19 PM
Belt routing larry408 YJ Wrangler Technical Forum 1 08-18-2010 07:18 PM
2.5L Fan Belt Routing feusaf TJ Wrangler Technical Forum 2 05-06-2008 06:36 PM
? about belt routing and OBA learfxr YJ Wrangler Technical Forum 3 06-04-2007 08:17 PM
Sanden Compressor Clutch work on a York Compressor? Stricken TJ Wrangler Technical Forum 2 07-14-2004 11:55 PM
