2.5L Airbox modifications - JeepForum.com
post #1 of 13 Old 02-27-2002, 06:10 PM Thread Starter
jeepinarkansas
1982 CJ8
Are there two restrictors that can be removed from a 2.5l airbox on the yj's? If so is the difference noticeable, and does it harm the engine? Does this mod compare to the cold air intake i see in catalogs.
Thanks,
Jake
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 13 Old 02-27-2002, 06:15 PM
JeepBeep
Your correct, there are 2 restrictors on the 2.5L. If you run a quick search of this YJ Forum you can find someone's exact tutorial of removal, (with pictures!). I have removed my restrictors and put in a K&N High Flow Filter. I've never used a Cold Air Intake, but the k&n+restrictors has shown results, initial first and second gear acceleration has shown improvement.
I'm not sure about the engine harming, isn't more air flow a good thing for the engine?
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #3 of 13 Old 02-27-2002, 06:48 PM
JeeperJay
Where is the second restrictor? I know about the one at the back of the airbox at the inlet tube, but thats it.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #4 of 13 Old 02-27-2002, 07:32 PM
95yj-4 cyl
The other is at the front of the airbox.
95 yj, 4 cyl, auto trans, 4:88 gears, detroit front locker, rear detroit with super 35 kit, short shaft conversion, 4" superlift, 32" superswamper radials
95yj-4 cyl is offline
post #5 of 13 Old 02-27-2002, 08:29 PM Thread Starter
jeepinarkansas
1982 CJ8
thanks for the input, but does it harm the engine, or could it?
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
post #6 of 13 Old 02-27-2002, 09:33 PM
I-4
I-4's Avatar
no,it won't hurt your engine.i have had both restrictors out of my jeep for over a year,and have had no harmful side effects.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #7 of 13 Old 02-27-2002, 09:57 PM
Mike611
Mike611's Avatar
Removing your restrictor also helps when your wheeling... It give's you just a slight, slight bit more low-end, so, your not working you clutch quite as much,, and while it's not a big difference,, any improvement for free is better than a jab in the eye with a sharp stick!
Mike
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #8 of 13 Old 02-27-2002, 09:59 PM
Mike611
Mike611's Avatar
P.S.---> this is for I-4,,,, how do you like your centerforce clutch? How much was it? What kind of difference can you tell? How hard is it to put in? you know, all that good stuff, thanks!
Mike,,,
Mike611 is offline
post #9 of 13 Old 03-04-2002, 03:42 PM
jfarrell
any comments or experience regarding 90 YJ on air box restrictors. If you know anything could you also see my post regarding the vacuum lines. not sure if they are on the 91 and up yj's?
Need some help...thanks!
jfarrell is offline
post #10 of 13 Old 03-04-2002, 03:54 PM
Nine5YJ
hey-
one of my friends has a 90 YJ 4 banger.. his airbox was different than mine and it didnt have any cones that we could find without ripping the whole thing apart...
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #11 of 13 Old 03-04-2002, 09:08 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
For the front, on the innerside, towards the fan, on the lower foward side, there is like a 2" x 3" plastic panel, pop that right off!
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #12 of 13 Old 03-04-2002, 11:05 PM
kidwired
kidwired's Avatar
skip the restrictors
put a 3 inch intake on!
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #13 of 13 Old 03-05-2002, 11:03 AM Thread Starter
jeepinarkansas
1982 CJ8
Please give me some more details on that.
Thanks
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 10:34 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 07:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 07:44 AM
Oil in Airbox? dabomb5756 YJ Wrangler Technical Forum 4 04-23-2005 11:35 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-22-2002 11:15 PM
