2.5L and 4.0L under dash wire harness interchangeable? - JeepForum.com
post #1 of 9 Old 04-22-2010, 05:05 AM Thread Starter
aaron0000934
Well I guess the title says it all. I have swapped a 4.0L out of a XJ into my 89 YJ. I am using the XJ harness under the hood. I am running a in tank fuel pump and would like a 92-95 under the dash harness to complete the build. Are the 2.5 and 4.0 under the dash harness the same? Does the 92-95 harness plug into the steering column connectors? I think I read somewhere that the speedo connector is different. Any thoughts would be appreciated, thanks
89 YJ unlimited with 4.0L
aaron0000934 is offline
post #2 of 9 Old 04-27-2010, 10:05 AM Thread Starter
aaron0000934
Really no one knows the answer to this question? There has to be someone out there with this knowledge.
post #3 of 9 Old 04-27-2010, 10:13 AM
Nitro_Man
I was looking at my Jeep manual yesterday for electrical diagrams. Everything is pretty much the same inside the Jeep for 2.5 and 4.0. 2 main connectors, one is above the e-brake, other at the steering column.
There are a few differences in the engine compartment, but not much.
Nitro_Man is offline
post #4 of 9 Old 04-27-2010, 10:17 AM Thread Starter
aaron0000934
perfect, thanks
post #5 of 9 Old 04-27-2010, 10:27 AM
1990offroadYJ
Yea i did a 4.0 into my yj with a xj motor and wiring too. i incorporated the inside xj harness and dash into my jeep for temporary because i was running out of warm weather. and i was told by a friend that the yj underdash harness out of a 92-95 would plug into the firewall of the xj engine harness.. but you will need to get 92-95 speedo and gauges to have all the same plugs. and not splice. i got all the stuff pretty cheap off of ebay i just have to do it now. and you will need to find a VSS to go into the transfercase to get the speedo to work because it is not cable driven its electronic. You also need the wiring to make it from the VSS to the engine wiring harness because it goes to the ecu and controls idle. like i said i used all the xj dash gauges except for the speedo and it stalls almost all the time when i step on the brake and clutch to slow down to a stop. if you have any questions just let me know. i did my swap it i love the power and it was my first motor swap aand it worked
1990offroadYJ is offline
post #6 of 9 Old 05-13-2010, 11:14 AM Thread Starter
aaron0000934
Well im glad im not the only one attempting this swap. I acquired a under the dash harness from a 92 YJ 2.5L jeep. I installed last night. All the connectors for the steering column were the same and also the light switch and dimmer. The heater box motor and heater controls worked too. There are a few others that I have not idea where they go. I am watching a speedo and temp, fuel, clock, guages on ebay from a 92-95. I also acquired a harness from the same jeep that goes to the tail lights. The connectors for the tail lights are different. I also cant find the connector for the fuel pump. Is that part of this harness? Also I have all the underhood harness from the XJ. I was going to use the headlamp harness from the 89YJ too. I was able to separate the XJ harness at the firewall and plug the headlamp harness in from the 89YJ. But does the other connector from the XJ control more than just the lights? hard to tell because they are all taped together. I guess i can plug it all together and see what happens. I have the harness that goes back to the tranfercase from the XJ so I think im ok there.
post #7 of 9 Old 05-16-2010, 09:15 PM
1990offroadYJ
the fuel pump is part of the wiringharness that goes back for the brake lights.
post #8 of 9 Old 07-07-2010, 09:52 PM
1990offroadYJ
did you every get the wiring done?
Im doing my wiring now and the passenger side of the connector isnt at all the same so i took out all of the wires out of the bulkhead and am putting them where they need to be.
post #9 of 9 Old 02-17-2014, 09:42 AM
ehamilton
I am trying the same swap but with a commanchee 4.0 from a 92 what will need to be changed. I hooked everything up and they are not the same. I currently found a 95 yj 4.0 engine wiring harness will this plug into and work with the 2.5 underdash wiring?
ehamilton is offline
ABS ECU & Wire Harness on Non ABS YJ MooCowMan YJ Wrangler Technical Forum 1 11-04-2009 05:49 AM
TJ Top of Dash Wire Harness MGPenn TJ Wrangler Technical Forum 2 07-17-2009 10:05 PM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
wire harness for dash roachy20 TJ Wrangler Technical Forum 4 05-30-2008 11:45 AM
New wire harness behind dash...no start Jeepinjon YJ Wrangler Technical Forum 9 04-30-2007 06:01 PM
