2.5l to 4.0l Throttle Body swap problem! No idle and Revs goes straight to Redline! - JeepForum.com
post #1 of 3 Old 08-01-2010, 09:32 AM Thread Starter
JTR2008
So I just swapped out my 2.5L throttle body and put in a 4.0L throttle body. everything went in smooth and everything is on tight, and I used the original sensors but when i turn the key and start the car, the revs just go straight up and doesn't stop and i shut the engine off right away. I checked the the flap and its staying shut. I'm no mechanic and i don't have a clue why it is doing this. Any help would be great.
JTR2008 is offline
post #2 of 3 Old 08-01-2010, 09:41 PM
Que89YJ
You have a vacuum leak. Check all the vacuum lines.
Que89YJ is offline
post #3 of 3 Old 09-08-2010, 06:41 AM
YelloJeep
Did you get this straightened out? I also just did this swap and when I started it I held my breath waiting for the RPM's to shoot up (I keep hearing people say that is what happens) but it started right up as if I had done nothing. I did notice that it idles around 900-1000RPMs but I can deal with that. I have noticed a pretty good difference in power (not HUGE..). I see alot more of 5th gear and I think maybe I can now turn some 33's without too much strain... Before I was thinking 33's would just be too much but now I think it can handle it.
YelloJeep is offline
problem with 4.0 throttle body swap cmarsh TJ Wrangler Technical Forum 5 08-15-2010 04:27 PM
problem with 4.0 throttle body swap cmarsh TJ Wrangler Technical Forum 3 02-02-2010 10:09 AM
Edge Throttle Body Whistle at Idle? TJShadow TJ Wrangler Technical Forum 17 03-25-2009 04:30 PM
Idle issue after 4.0l Throttle body swap wranglerkid95 YJ Wrangler Technical Forum 13 03-16-2009 02:31 PM
Redline at startup - throttle problem jonstine TJ Wrangler Technical Forum 27 01-07-2003 02:59 PM
