2.5l to 4.0l swap underway. - JeepForum.com
post #1 of 3 Old 12-20-2006, 06:50 PM Thread Starter
ID89YJ
ID89YJ's Avatar
I got a wrangler 4.0 wiringharness and computer from a 92 and a 94 engine from a xj, I hope these are compatable. I got a 5 speed tranny from a 98. I got the package deal for 1250.00. I hope the 94 engine is obd1, because it was the lowest mile one they had. My 2.5l wrangler should have the fuel pump in the tank so i should be good there. I will have to get the vss adapter gizmo from hesco, i am open to ideas if you guys have any. I hope that i have chosen corectly on the parts. What will i do on the t case? The 2.5 231 wont fit the ax15 , correct?? I need to make sure the ax 15 is out of the wrangler aplication, i'm pretty sure it is.
Ideas or opinions are welcome.
Steve
1989 Wrangler... 93 4.0L , AX15 ,231 TC,Rough Country 4inch lift, 33 12.50 Baja Claws .
ID89YJ is offline
post #2 of 3 Old 12-20-2006, 07:34 PM Thread Starter
ID89YJ
ID89YJ's Avatar
Thanks Scott, aka Tomb Raider
Steve
ID89YJ is offline
post #3 of 3 Old 12-20-2006, 08:44 PM
hampton
swap
Just did this last week except went to 4.2. Get a complete donor jeep and work from that or it will nickel and dime you to death. Don't forget to move the motor mounts.
hampton is offline
2.5-4.0 swap is underway!! RnEmOvr TJ Wrangler Technical Forum 172 04-28-2017 08:23 AM
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
