2.5L to 4.0L swap - Page 3 - JeepForum.com
post #31 of 35 Old 04-07-2013, 09:21 AM
Que89YJ
pull it from another ecu connector. you will need the injector plugs too.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #32 of 35 Old 06-04-2013, 08:29 AM
Johnfire
Does anyone have what the measurement are on the engine perch move. I have just started working on the same swap and have cut off the old mount very carefully. The big difference is I am working with just the frame at the moment and I don't have a transmission cross brace/skid plate to base my engine location off of. I will start a post on my build here after I get done doing some work on mine today.
Johnfire is offline
post #33 of 35 Old 06-04-2013, 09:11 PM
Wild Hare
i moved mine forward 3 7/8 and its a lil tight against the firewall. 4 1/2 would have been better.
Wild Hare is offline
post #34 of 35 Old 06-04-2013, 11:11 PM
Johnfire
Thank you
Johnfire is offline
post #35 of 35 Old 06-06-2013, 09:24 PM
imstillatwork
Awesome! Any of you guys with a donor still have two ECU wires you can pull out and send me (I'll pay for em) No junkyards around here for hours around. Injector wires and the transfer case input gear are all I need now. I have EVERYTHING else waiting in the garage.
imstillatwork is offline
4.0l , engine rebuild , engine replacement , engine swap , engine swap wiring
