2.5L to 4.0L swap - JeepForum.com
post #1 of 35 Old 02-23-2013, 07:50 AM Thread Starter
Sgtrhoads
2.5L to 4.0L swap
I started this project awhile ago. I have a 95 YJ w/ 2.5L AMC and automatic. Last spring I found a worn out 95 here in NNY with the 4.0L and also automatic. Picked it up pretty cheap. Frame was rusted and cracked, but the engine looked good and ran. I torn it down, had the lip taken out of the cylinders and got the head cleaned. I have ordered a Clegg master rebuild kit that should be in this week. I plan to put it back together and swap it out with my 2.5L. I saved everything I think I needed from that rusted jeep before I junked it. I have the wire harnesses, ECU, XMSN, and a few other things. I am supposed to deploy to AFGN in a very short amount of time.
Does anyone have any pointers or info that might help me get through this with the least amount of issues. This is my first engine rebuild and engine swap. I am an aviation mechanic, and learning my way on vehicles. Any info you guys (and gals) have would be greatly appreciated.
Sgtrhoads is offline
post #2 of 35 Old 02-23-2013, 08:46 AM
schaef89
I hope you saved the transmission too. The 6 and 4 cyl have different transmissions
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #3 of 35 Old 02-23-2013, 08:53 AM Thread Starter
Sgtrhoads
Oh I did. Want sure on that but figure better safe then sorry
post #4 of 35 Old 02-23-2013, 09:05 AM
schaef89
Ok just making sure since you didn't say that in the original post.
It might be easier to put in 2 more injector wires in your existing harness instead of swapping the hole thing out. The 4 an 6 share the same harness just different injector wire count
schaef89 is offline
post #5 of 35 Old 02-23-2013, 10:02 AM Thread Starter
Sgtrhoads
Thanks I'll look at that. Never look at the differences.
post #6 of 35 Old 02-23-2013, 06:56 PM
jeepcrazy93
When i did mine i added the injector wires. Its tricky but not that hard. Its good that you have a donor vehicle. The miscellaneous parts to do the swap can add up.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #7 of 35 Old 03-06-2013, 08:18 PM Thread Starter
Sgtrhoads
Starting to get it back together.
post #8 of 35 Old 03-07-2013, 08:22 AM
Que89YJ
The harness between the 2 is almost the same. You might have to extend the coolant temp sensor wires and play with the alternator wires. Adding the 2 injector wires is definitely the easiest way to go on the harness. It really looks great! Keep the pics coming.
Que89YJ is offline
post #9 of 35 Old 03-08-2013, 08:03 AM
remmons
This will be a fun project for you. You will love the end result once you're finished and fire it up for the first time. Keep us posted on your progress.
Robert.
remmons is offline
post #10 of 35 Old 03-08-2013, 08:45 AM
bogleparsons
Dang I wish i had a 91+ model so i could do the 4.0 swap easier
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #11 of 35 Old 03-08-2013, 09:15 AM
Que89YJ
Hey Bogle. It is easy enough to do ours. It is the same basic swap as the 4.2L guys. I want to do the swap on mine but I just have too many other things to do right now.
Que89YJ is offline
post #12 of 35 Old 03-08-2013, 09:53 AM
bogleparsons
oh, that's good to hear. I thought because of the TBI it wouldn't work.
that motors purty btw, keep us posted.
post #13 of 35 Old 03-09-2013, 02:18 PM
riptide69
I was under the impression we couldnt do the swap with a '90 because of the transfercase and the axles being of lower quality than the 4.0 drivetrain..was i given bad information? thats the only reason i havent done the swap.
riptide69 is offline
post #14 of 35 Old 03-09-2013, 05:11 PM
Wild Hare
axles are the same doesnt matter 2 or 4 banger
Wild Hare is offline
post #15 of 35 Old 03-09-2013, 05:13 PM
Wild Hare
what are the plans for motor mount relocation?
4.0l , engine rebuild , engine replacement , engine swap , engine swap wiring
