2.5L with 33's with 3.7 gears whos done it?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2.5L with 33's with 3.7 gears whos done it??
50" LED CREE Light Bar Pair With Wiring KitFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-02-2013, 11:08 AM   #1
apougnet3701
I have a 1995 2.5l automatic with stock gears 3.7.. I have been offered four 33" Mickey Thompson Baja tires almost new for 250 with jeep rims from a good friend. I'm defiantly buying them I just want to know if anyone has ran these tires on the 4cyl with stock gears and how t ran. I know I will have a loss of fuel economy and power but how bad is it? I can go 70k no problem with 31's please let me know thanks.
apougnet3701 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 11:22 AM   #2
dadstoy
Good price on the tires, but I think you will not be happy. I had a 2.5 with 33's and 4.10 gears and 5th gear was just a number on the stick. I could go 75 comfortably. I am wondering if 4th gear would even be useable for you.
dadstoy is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 11:22 AM   #3
apougnet3701
I would like to add this is my dd and I don't plan to swap out the Dana 35.. I just wanna know of its a food or bad idea to run these tires and of anyone does what they think. I do drive on the highway often.. Thanks in advance
Unread 02-02-2013, 11:23 AM   #4
apougnet3701
It's an automatic not standard. I think they came stock 3.7 gears
Unread 02-02-2013, 11:27 AM   #5
johnboy68
HIP2BSQR
johnboy68's Avatar
Most will say you should start thinking about re-gearing and upgrading your rear axle to something like a Ford 8.8.
I don't have any experience with your setup but expect what you have already posted. You can't beat that price and since they are already mounted on Jeep rims it's a simple swap to see how it does. Even if you don't like it you won't have any problem getting your money back out of them.
johnboy68 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 11:30 AM   #6
apougnet3701
Ya that's what I was thinking. Try them out for a week and if they aren't bearable I can switch back. Thanks. I'm hoping someone on here has done it
Unread 02-02-2013, 11:30 AM   #7
Renegade88
Yes the automatic have 3.73 when I owned my 4cyl TJ with the auto I borrowed a set of 33's from a buddy to see how DD would be and after 2 weeks I could not stand it and put my 31x10.50's back on. So if you DD it and have to get on the highway I would advise against it until you can afford to regear.
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 11:43 AM   #8
apougnet3701
Ya that's what I thought I was gonna hear.. How was it on the highway? Could you get up to speed??
Unread 02-02-2013, 11:44 AM   #9
apougnet3701
As Long as I can go 65k I'm okay with that speed i just don't want to use 40 gal of gas a week
Unread 02-04-2013, 02:55 PM   #10
apougnet3701
What didn't you like??
Unread 02-13-2013, 07:40 PM   #11
ldso
I ran 285/75r16's with 3.73 gears and the 2.5L manual transmission, it brought teh suck! I mean it was drivable, you just had to floor it more than usual. I just did that for a few weeks while working out the kinks with my axle swap, then took it to a shop where they installed my 4.88 gears.
I drove for 6 months on 34" bias Swampers with 4.10 gears, it sucked but those tires were badass.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline   Reply With Quote Quick reply to this message
